Throttle return spring.....
Old Dec 21, 2007 | 06:53 PM
turret_plug's Avatar
turret_plug
Can some one please give me some ideas on how to set up my throttle return spring on an edelbrock SB manifold.... every spot I try is too close, too far away....etc....pics would be nice too
Old Dec 22, 2007 | 09:03 AM
Franklin2's Avatar
Franklin2
Just get a small piece of metal and drill a hole in one end big enough for one of the intake manifold bolts to go through. Drill a hole in the other end for the spring. Unbolt one of the manifold bolts and put the new spring bracket underneath the bolt and tighten it down.
Old Dec 22, 2007 | 10:04 AM
turret_plug
Thanks, never thought of that one, my old setup was a straight bolt in the manifold that stuck up about 3 inches
Old Dec 22, 2007 | 11:52 AM
jinserra's Avatar
jinserra
on mine the return spring is part of the throtle cable.
Old Dec 22, 2007 | 12:02 PM
turret_plug
well, my cable has a spring that pushes it back, but sometimes it does not go all the way back in, so I need the return spring, you know, idle low... hit throttle, idle high, back and forth..... pissing me off, i will try franklin's idea, I bought a new manifold bolt set and need to put them in anyhow.
Old Dec 22, 2007 | 11:13 PM
turret_plug
This is what I came out with franklin... I hooked the bracket up to a valve cover bolt instead of the intake, worked out ok i think, Here is a picture on the link below, please let me know if you see any problems or improvements I can make
https://www.ford-trucks.com/user_gal...171563.520.390
