Bad Idle
Old Dec 21, 2000 | 05:23 PM
skipper's Avatar
skipper
Bad Idle
In advance I would like to say that I am sorry for the length of my question. I have an '83 Ford Bronco with a 300ci straight six. Everything is stock. It starts fine, but while running at idle the engine will rev up and down. It starts at normal idle, starts sputtering until it almost stalls, then quickly revs up again, then sputters and revs up again and the cycle goes on as long as the engine is at idle. Once the engine idles for a couple of minutes the revs get farther and farther apart until it stalls. It is as if it keeps loading up, which is likely since the exhaust sprays out lots of carbon. My truck leaves a five foot spray of dark black carbon across the snow. There is no smoke though. I am almost positive the carb is dumping excess gas into the engine and have messed with the rich/lean screw at the base of the carb, but it doesn't affect anything. There is no change in idle. The truck has all of the pollution control stuff on it but none of it is hooked up. My smog pump is seized up and there is no catalytic converter and no pollution control sensors are hooked up, in case that is relevant. I just want to know why my truck has such an erratic idle and how to fix it. Any help would be greatly appreciated. Thanks.
Old Dec 23, 2000 | 06:30 PM
rlbertrand's Avatar
rlbertrand
Bad Idle
Sounds like something in the carb is hosed - sticking needle valve maybe? Choice is either rebuild current or buy a new/reman carb. I would lean toward rebuilding - depending on the cost of the kit and how much you want to tear into the carb!!
Good luck at let us know how things turn out
Old Dec 25, 2000 | 06:47 PM
jonive's Avatar
jonive
Bad Idle
Black smoke indicates you've got a rich fuel mixture. If attempting to adjust the idle mixture doesn't change anything then the problen is probably the float in the carb, needle vavles , plugged or some other internal problems. Time to either rebuild or have a remanufactured one put on. The surging could also be from a vacum leak, so check out your connections, lines, egr valve and gasket, intake/exhaust manifold bolts, and also check out how tight the carburetor is to the manifold. Any leaks around the carb can cause it to burn rich.
Old Dec 26, 2000 | 07:43 PM
curti's Avatar
curti
Bad Idle
carburetor is to
>to burn rich.
Leaks will cause a lean mixture, not rich, Jonive.
Skipper, when did this start? Was it a progressive thing or sudden? I wonder if you may have old gas, dirty fuel filter, water in gas, Just aguessin'.
Good luck, Curti
Old Dec 27, 2000 | 06:04 PM
billyb's Avatar
billyb
Bad Idle
check the choke. the choke doesn't just operate the plate on top of carb, it also operates the pulloff and ups the idle, and makes engine run richer!!! until warm. then it returns to normal if not malfunctioning. had same symptoms on old (yikes) blazer.
Old Dec 27, 2000 | 11:44 PM
skipper's Avatar
skipper
Bad Idle
Thanks for the advice guys. I think that if I am looking towards a new/rebuilt carb that I will just wait until summer and buy a new intake and a four barrel carb. Until then I will check for vacuum leaks, all of the filters, and the egr valve to see if that helps a little. Thanks again.
Old Dec 29, 2000 | 02:34 PM
Eddie's Avatar
Eddie
Bad Idle
General Geoff
Dec 29, 2014 05:29 PM
Odd_Ball
Nov 26, 2010 09:41 PM
shooter05
Aug 31, 2007 08:58 AM
jimbo81587
Apr 29, 2004 07:59 AM
jakerot
13
Dec 28, 2002 01:02 AM
