Help!!! Won't Fire
Old Dec 20, 2007 | 08:08 PM
John_deere_kid's Avatar
John_deere_kid
Help!!! Won't Fire
We have some issues. I cant get my truck to fire. It will turn over all day long. Has great spark, new distributor cap, rotor, new plugs, new plug wires, starter solenoid, starter are also new. Everyone I talked to said it was the ignition module, so I pulled one off wrecked F150 with the same motor (Same year to) and put that on tonight. Same thing. Turns over but wont start. Has good compression to. We cant even get it to actlike its gonna start off of ether.
Any ideas? Im desperate. Thanks in advance
1993 F150
4.9L I6
Fuel Injected
Old Dec 20, 2007 | 08:12 PM
dixokai's Avatar
dixokai
If you have spark it's more than likely not the ignition module. I would suspect fuel pump, fuel filter, etc. Check your fuel pressure. Do you hear the fuel pump run?
Try a little bit of starting fluid, if it fires then it's fuel related
Old Dec 20, 2007 | 08:14 PM
dixokai's Avatar
dixokai
Woops, you did try either.... If you have spark, it should have fired.
Old Dec 20, 2007 | 08:22 PM
John_deere_kid
Thats what I would have though. But it didnt.
Old Dec 20, 2007 | 09:01 PM
subford's Avatar
subford
Did you check for codes?
Other things that would cause this are:
TPS
ECT sensor
EGR Valve stuck open.
Old Dec 21, 2007 | 12:24 PM
John_deere_kid
Nope, havent done a code scan yet as I have it at home in my garage and we dont have code scanner there
Old Dec 21, 2007 | 02:10 PM
quicklook2's Avatar
quicklook2
just need a paper clip to read codes.
if it has spark it should fire with starting fluid.
Old Dec 21, 2007 | 11:41 PM
John_deere_kid
Paper Clip?
QL2, thanks again for the CD Manuals. I greatly appreciate them and have gone to them quite a bit for information.
Old Dec 22, 2007 | 05:21 AM
subford's Avatar
subford
Originally Posted by John_deere_kid
Paper Clip?
To check your codes go to one of these links below:
This is good for the KOEO test:
http://fordfuelinjection.com/?p=13
This one is good for the KOER test:
http://www.broncodata.com/tech/codes.htm
Old Dec 23, 2007 | 09:27 AM
John_deere_kid
Guys, no one is gonna wanna believe me when I say this. But I had my one buddy come over and give me a hand with testing stuff and everything else that has been mentioned. When he walked in the door he said turn it over I wanna hear what it sounds like. I hit the key, waited for the check engine light to come which was like a second, heard the fuel pump, moved it to start it and fire right up. I didnt believe it. Let it run for a bit, then turned it off. Checked a couple of things then fired it up AGAIN. I dont got a clue. Im kinda wondering if there might be a bad spot in the fuel pump.
Merry Christmas and Thanks Again.
