Sponsored by: Real Truck
250 SD Rear Brake Question
Old Dec 20, 2007 | 06:03 PM
joeskeeter's Avatar
joeskeeter
I have a 2000 250SD CC SB with rear disc brakes. How in the heck do you get the rear rotors off ? It looks like they should slip right off. Do I have to pull the axel? Or is there some special tool to help get them off.
Thanks
Old Dec 20, 2007 | 06:19 PM
Toyman's Avatar
Toyman
They will slide off of the hub. You will most likely have to hit it with a hammer to get it loose, use a piece of wood so you don't damage the surface if you are reusing them. I replace my rotors with new slotted units, so I just hit the surface until they came off.
Toyman
Old Dec 20, 2007 | 07:13 PM
Rongold's Avatar
Rongold
Rear Rotor Removal
They should just slide off unless they're rusted to the hub. If they are rusted, spray them with some penetrating oil, and if you are going to replace them, just beat the living s%&t out of them with a BFH. If you are going to reuse them, beat them off using a piece of wood between the rotor and the BFH. Make sure that your emergency brake is released.
RON
Old Dec 20, 2007 | 07:22 PM
redford's Avatar
redford
FTE Leadership Emeritus
Swear
Beat them into submission.
Get angry
(Make sure your parking brake isn't on )
Old Dec 20, 2007 | 08:56 PM
DCSpecial's Avatar
DCSpecial
Smack the back with a soft faced dead blow hammer.....if you are replacing the rotor, use a mini sledge. Rotate as you are doing this. Spray plenty of penetrating oil as mentioned around the hub....I always use PB blaster.
Old Dec 20, 2007 | 08:59 PM
joeskeeter's Avatar
joeskeeter
Thanks for the info guys, got them off but were too thin to be turned SO bought a couple of ORielly's lifetime's. Did break one of the caliper carrier bolts so can't finish tonight have to go to Henry's house tomorrow to get it.Again thanks for the quick response and info.
shu5720
Mar 7, 2008 05:42 PM
cowboysoldier
Sep 25, 2005 07:42 PM
fourducs
Sep 17, 2004 08:10 PM
SHADOWDUDE
May 5, 2004 08:14 PM
