Power Loss
Old Dec 20, 2007 | 09:49 AM
vroc55's Avatar
vroc55
Red face Power Loss
Good Morning, I spent the better of two hours surfing. Quit a nice forum. Lots of knowledge on this site.
Need some feed back! I found this 1965 Ford Step Van pretty much left for dead. I bought it and started fixin it up. I believe the engine is a 300 cid but could be a 240 in line six. Cleaned it all up first, and then began trouble shooting its illness. New battery, new plugs, wires, rotor, points condenser, fuel pump, new carb - carter Y type single barrel, oil and air filter, Fuel pump and in line filter. New intake and exhaust gaskets.
Motor flushed as best I could with new oil and filter. Pulled fuel tank, flushed and cleaned. New fuel lines.
Transmission is a 3 speed manual crash box. small
Timing set at 10 degrees with rotor pointing to #1 front cylinder. Wired for 1-5-6-3-2-4 timing.
Compression Test- 1,2,3,5,6 -125 lbs #4-98 lbs.
Problems: First the engine starts right up, but tends to accelerate and de-acceeratre by itself. Timing chain?
Runs good, and revs up nicely while in nuetral. Took it for a test drive. First gear power and rpm's seem normal, a little hesitation or power loss in 2nd, and then it seems to not want to gain rpm's enough to shift from 2nd to 3rd. When I shifted it to 3rd it bucks , pedal is to the floor.
Any suggestions?
Old Dec 20, 2007 | 09:53 AM
Mr Jimi's Avatar
Mr Jimi
Welcome to the forum and I can't help you with your problem but I own a 16 foot stepvan and I use mine for camping mostly and I love it
Jim
Old Dec 20, 2007 | 10:43 AM
Fomoko1's Avatar
Fomoko1
Hi and welcome vroc55.
For suggestions and help on your problem with the 300-6 post in the Inline Six, 200, 250, 4.9/300 forum: https://www.ford-trucks.com/forums/forum52/
Be sure to visit the Fl chapter: https://www.ford-trucks.com/forums/forum116/ and post your intro.
Old Dec 20, 2007 | 03:57 PM
vroc55's Avatar
vroc55
Thanks,
vroc55
Nomadicendevors
New Member Introductions
Dec 29, 2017 12:19 PM
papatango
Jan 9, 2015 11:49 AM
Nitramjr
47
Apr 28, 2009 10:47 PM
Thudpucker
Feb 6, 2001 09:34 AM
