6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
leaky radiator
Old Dec 19, 2007 | 08:10 PM
2008drkstone's Avatar
2008drkstone
leaky radiator
well i had just said about a day or two ago that i had my 6.4 problem free, wrong . Got home today from work and forgot something in truck as i walked up to my truck i saw a couple of drops of liquid on the ground. As i did a better inspection i notice that it was from passenger side bottom of radiator, sdhflkslj! I called my dealer and asked if i could come in and get this checked out. After they inspected they said YES its your radiator . But after they went to check in there inventory i was relieved to find out that they had 2 in stock. Will be going in the morning and they said they sould have it done by in the afternoon as they are not too busy and they have a diesel tech available. Who else has had this problem and was it fixed the right way?
Old Dec 19, 2007 | 08:55 PM
Tom Hoffman's Avatar
Tom Hoffman
Make sure it is a certified rad that has the newer numbers or you will be back!
some folks out here have had 3 or 4 radiators
Old Dec 20, 2007 | 02:27 PM
phill1060's Avatar
phill1060
can you explain this some more?
Old Dec 20, 2007 | 04:41 PM
Tom Hoffman
Ya a bunch of radiators are junk and FMC did not know how many, the dealers put new junk radiators back in the trucks
A few hundred miles you where back for another (Made in Mexico) radiator! keep on
going to mexico Ford
Old Dec 20, 2007 | 06:53 PM
Maxium4x4's Avatar
Maxium4x4
All the information is right here, keep reading
https://www.ford-trucks.com/forums/6...-leak-tsb.html
Old Dec 20, 2007 | 08:19 PM
Sayonara's Avatar
Sayonara
Good thing they had one for you! Hopefully it will be a quick fix.
BTW - Nice Truck!!
Old Dec 21, 2007 | 06:21 AM
Exposed's Avatar
Exposed
Radiator ......
Is leaking the only evidence of a bad radiator??? So far, mine shows no evidence of leaking. My F-550 was built the week of January 8. So it is almost a year old....I am assuming this was a bad batch of radiators that made it in the earlier production....
