Sponsored by: Real Truck
ESOF help 2001
Old Dec 19, 2007 | 12:42 PM
Gmeanie's Avatar
Gmeanie
ESOF help 2001
Need some help with the ESOF.
I changed my vacuum lines to the hub and when i take the hose off there is no vacuum getting to them?
So i did the test with the AC and it dosn't switch over to defrosters and my 4x4 light on the dash works. If I lock them manually they work fine.
I would like to get this fixed because there is sometimes when going up peoples driveways I think I can make it to find myself stuck and have to manually lock them.
Would anyone have a pic where the PVH solenoid is on a 2001 so I can check that next.
thanks
Old Dec 19, 2007 | 01:29 PM
Gmeanie's Avatar
Gmeanie
damn they want 45.00 for the PVH solenoid it would suck if it isn't that.
Old Dec 19, 2007 | 02:35 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Did you turn the ac on then turn the switch to 4x4? Might take a couple mins for the ac to go to defrost.
Old Dec 19, 2007 | 04:32 PM
Gmeanie's Avatar
Gmeanie
I didn't wait 2 minutes waited about 20 seconds. I will try that.
Old Dec 19, 2007 | 09:14 PM
Gmeanie's Avatar
Gmeanie
I waited 5 minutes and the AC was blowing out the vents in front of the dash not the defrosters?
What does that mean?
Old Dec 20, 2007 | 09:25 AM
Gmeanie's Avatar
Gmeanie
Anybody?
The part is in and don't want to buy it if I don't need it.
Old Dec 20, 2007 | 09:45 AM
Gmeanie's Avatar
Gmeanie
When putting my fingers on the two nipples of the PVH solenoid shouldn't I feel a suction? Right now there is nothing. When the truck is running the red line is blowing air if I am right the black line does nothing. I can't seem to blow threw the black line either with my mouth.
Old Dec 20, 2007 | 09:57 AM
Ed in Maine's Avatar
Ed in Maine
Did you check for voltage to the soleniod? You should be able to hear it as well.
I beat those are just little diaphragm jobbers with a check valve, which could be torn? Especially if water got in the line and froze..
Old Dec 20, 2007 | 11:02 AM
Gmeanie's Avatar
Gmeanie
It was the PVH it works now.
One more question in the front with the 4x4 on does only one side spin? Is it slip?
I thought both would spin kind of a NEWBIE here on this matter.
Weird thou with it idiling in 4x4 I don't hear the new one either?
Old Dec 20, 2007 | 12:07 PM
miller_feed
Only the rear has limited slip, the front is an open unit. And yes one front will grab the other will not depending on traction.
BTW: Glad you got it fixed.
Old Dec 20, 2007 | 12:28 PM
Gmeanie's Avatar
Gmeanie
Ok Thanks for the help guys you got me threw this fix and I thank you for that.
