will it work
Old Dec 19, 2007 | 10:26 AM
ricg's Avatar
ricg
will it work
well i found a motor but not sure if it will work....they said it came out of a 04 f250 just like mine but they dont have a vin number on it....is there any way i can find out if it will bolt straight up with no problems......or does it matter????
Old Dec 20, 2007 | 03:09 PM
ricg's Avatar
ricg
can someone help me out....please
Old Dec 20, 2007 | 06:44 PM
toolman05kr's Avatar
toolman05kr
Look it over real close, if everything maches up then it's a smooth swap. some early motors had the ics sensor below the turbo, late 03 and up Its on the valve cover. Hope this helps and good luck.
Old Dec 20, 2007 | 07:08 PM
Maxium4x4's Avatar
Maxium4x4
Easiest way to tell an 03 from an 04 is the intake. 04 is a big U shape the 03 has a cross over in the back. The ICP sensor is located on the valve cover for an 04 and under the turbo at the back of the engine for an 03 just as toolman05kr stated...... you can use the parts from your old engine to change anything.
Old Dec 21, 2007 | 08:54 AM
ricg's Avatar
ricg
thanks for the info it helps out alot....i let yall know how everything works out....
