melted wires
Old Dec 19, 2007 | 08:44 AM
Bluestone's Avatar
Bluestone
Unhappy melted wires
head light switch wires melted,repaired( can i replace with out rewiring whole truck) new switch, only headlights. jumped parking to head light they work now not off switch. also problems with key accessery dont always shut off radio blower ect. replaced colomn and key ??????? thanks dan
Old Dec 19, 2007 | 12:29 PM
JoeTrotter's Avatar
JoeTrotter
Not too sure, maybe there's one wire harness affecting all this? Sounds kind of random, so I'm really just bumping this.
Old Dec 19, 2007 | 08:18 PM
F350-6's Avatar
F350-6
Did you recently add any additional lights to your truck? Where did the wire melt?
Old Dec 20, 2007 | 08:44 AM
Bluestone's Avatar
Bluestone
melt down 2000 f350
from switch to about a foot into harness
Old Dec 20, 2007 | 09:27 AM
F350-6's Avatar
F350-6
I don't think I've ever heard of wires melting there before. There's a possibility you've got a chaffed wire somewhere that when it grounds out melts the wires but that's supposed to blow a fuse. If your concerned you could always wire an inline fuse where the wire melted last time so you don't have to start replacing everything.
The other option would be to ohm the wires to see if you've got a short to ground somewhere, but that usually is an intermittent problem and hard to trace down.
Old Dec 20, 2007 | 02:37 PM
Bluestone's Avatar
Bluestone
the whole harness is cooked not just a wire or two
Old Dec 20, 2007 | 06:53 PM
F350-6's Avatar
F350-6
Wow, that's not good. It seems like there are 2 plugs on the back of the headlight switch. Did both sets of wires melt or just one set?
Did this happen when you were driving with the lights on, or did it happen when you turned the lights on? Do you have fog lights on your truck & if so, were they on or off? Any problems with your switch prior to this, or did you get any blown fuses?
Sorry for all the questions, just trying to figure out what the cause was. Your going to have to at least replace at least a good portion of the harness but I'd be worried about diagnosing the cause since you have a work around for now.
Old Dec 21, 2007 | 07:29 AM
Bluestone's Avatar
Bluestone
one day lights not working pulled switch and found a rats nest ,also dont use cheap fuses the dont pop the just melt, dont know if that was the fuse need to keep checking
Old Dec 21, 2007 | 08:07 AM
zx250's Avatar
zx250
Of the next Riffraff East
Now when you say "rats nest" do you mean a real rat? If so you may be chasing electrical gremlin for a long time. Sounds like you have shorts on both sides of your fuse panel. I would get a good fire ext. and keep it handy until you find all of your problems.
man-o-war
33
Dec 24, 2014 09:15 AM
chriscrna
Jun 26, 2012 03:36 PM
imabaka
Jul 24, 2011 12:51 PM
archangel
Electrical Systems/Wiring
23
Sep 1, 2007 12:19 AM
farlight7
Jan 25, 2006 03:51 PM
