Offroad & 4x4
New twin stick!
Old Dec 18, 2007 | 08:43 PM
78250crewcab4x4's Avatar
78250crewcab4x4
Thumbs up New twin stick!
If you have an NP 205 and have not twin sticked it yet you should be flogged, it is so cool, I used the kit from JD custom fab, it's great, except with a manual trans the levers could be shorter to clear the trans shifter better. Anyway, if you wheel at all this is an upgrade you SHOULD DO!
Old Dec 18, 2007 | 09:05 PM
77f150got_sand's Avatar
77f150got_sand
I have the same kit on mine, I just have a problem with the shift boot because I have a body lift it likes to pull the levers out of gear. Otherwise, I love it! I have mine behind a zf 5speed and had to heat and bend the twin sticks a little so all the levers would work without interfering.
Old Dec 18, 2007 | 09:22 PM
78250crewcab4x4
Here are some pics
Old Dec 18, 2007 | 09:25 PM
fishmanndotcom's Avatar
fishmanndotcom
haha, the really cool part is if you get line locks front and rear! that way you can lock one end of the truck
show us some front wheel burnouts
-cutts-
Old Dec 18, 2007 | 09:33 PM
78250crewcab4x4
-cutts-
I think I'll wait until I find a front 60 my truck has been down for almost a year, I kinda want it to last awhile
Old Dec 18, 2007 | 09:34 PM
78250crewcab4x4
-cutts-
K I can edit it but how do I delete it?
Old Dec 19, 2007 | 06:41 PM
STGFordCrazy04's Avatar
STGFordCrazy04
Did you buy the kit with the new shift rails or did you grind them yourself? Did you have to pull the xcase to do it or could it be done with it in the truck?
Grinding the rails is something Id screw up. Dont ask why but I just know me.
Old Dec 19, 2007 | 06:53 PM
78250crewcab4x4
I ground the rails myself, it was pretty easy, though the instructions were kinda lacking, look up the petersons 4wheel and off road article, it shows how to grind them better.
The case was out of the truck already, but I would not attempt to try it with it in the truck. It really is pretty easy, I think I could do it without instructions now.
Old Dec 19, 2007 | 06:54 PM
projectnitemare's Avatar
projectnitemare
I ground the rails on mine, worked like a charm. You need to pull the case to get the rails out. Making a set of shifters isn't too bad if you have a few extras to spare.
Matt
Old Dec 19, 2007 | 06:57 PM
STGFordCrazy04
Thats my hangup. I dont want to pull the heavy **** 205. I will one day though. Thanks
Old Dec 19, 2007 | 07:00 PM
78250crewcab4x4
I was impressed with the stuff from JB, I don't think I could round up all that stuff for $100. It comes with nice quiet rod ends and new hardware the stuff is stainless too.
I'm the kind of guy who would rather build everything myself, rather than buy from someone else, but I wouldn't mess around with trying to fab the linkage and stuff in this instance, and I'll probably buy the same kit for my resto truck.
my .02
Old Dec 19, 2007 | 07:06 PM
STGFordCrazy04
I agree. I build some stuff and buy some stuff. Sometimes you find that you cant build a part for what it cost to buy it off the shelf
Old Dec 19, 2007 | 07:08 PM
SoArkSI's Avatar
SoArkSI
is this the kit that they sell at bronco graveyard? its in their new 73-79 f-pickup catalog.
when you talk about the shifters interfering with the manual trans, in what gears did the hit?
Old Dec 19, 2007 | 07:13 PM
78250crewcab4x4
I ordered it off of JB's site, so I don't know if it's the same.
Second gear was the biggest issue, but they bent pretty easily, with the torch. fourth gear Barely interfeared before I bent it.
Old Dec 19, 2007 | 07:16 PM
SoArkSI's Avatar
SoArkSI
so 2wd hi and 2nd gear hit......you think that they would of did some testing for that. if i buy a kit, i wouldnt want to have to work on it, but i guess i would if there was no other choice. thanks for the help
