check engine light...
Old Feb 20, 2001 | 05:10 PM
reddogg's Avatar
reddogg
I was wondering what is going on when the check engine light flashes 2 or 3 times, then a short pause, then flashes again, etc.
I have only seen this when it it very cold out.
And it only does it for 2 or 3 minutes.
Any clues?
Old Feb 20, 2001 | 10:59 PM
PAUL_2's Avatar
PAUL_2
What model yr truck do you have ?
Old Feb 21, 2001 | 05:45 PM
reddogg's Avatar
reddogg
89 custom 4x4 5 speed
Old Feb 21, 2001 | 06:25 PM
towing_joe's Avatar
towing_joe
My truck does the same thing when it is very cold out and I have not given it time to warm up. I have an 89 F-150 300. I hooked up a diagnostic tester and it mentioned the EGR valve. My guess is that either the air is so dense it throws off one of the sensors or my EGR valve needs to be replaced in the future. If I am very careful on the throttle I can make it stop flashing, but it only does the 2-3 flashes in sub zero temperatures.
Old Feb 21, 2001 | 11:25 PM
PAUL_2's Avatar
PAUL_2
Check your Ecu for any stored fault codes & post what you find .
Old Feb 22, 2001 | 01:23 PM
martinb's Avatar
martinb
ImAGirl
Aug 3, 2015 03:13 AM
rcdriver11
May 28, 2008 12:09 AM
akidagin
Dec 10, 2007 01:00 PM
rustee90-150
Nov 11, 2007 05:03 PM
