Power drainage
Old Dec 18, 2007 | 08:48 AM
bsward's Avatar
bsward
Power drainage
I have a 88 F-250, and the battery keeps getting drained somehow. What would cause this, and how do I go about trying to fix it? thank you
Old Dec 18, 2007 | 11:15 AM
Conanski's Avatar
Conanski
Check your charging voltage(with a DMM) at the battery terminals with the engine running, it should be 13.5-14v. With the engine off you should still have 12.5 volts. Disconnect 1 battery terminal and measure voltage again, should still be 12.5v.
The usual suspect for a draining battery is the alternator, or more correctly the integrated voltage regulator and rectifier. These are often incorrectly diagnosed as OK on the benchtop testers at parts stores. These parts can be changed but the case is hard to get apart, so it's easier to just get a rebuilt alternator.
Old Dec 18, 2007 | 02:22 PM
bsward's Avatar
bsward
Thank you very much.
wpnaes
Jul 15, 2013 09:18 PM
Trulyvintage
1947 and Older Ford Trucks
May 20, 2011 10:40 AM
nflfreak43
Tennessee Chapter
101
Feb 10, 2010 12:47 PM
HiSPL
Testing.....
Aug 19, 2009 05:52 PM
Ford_Six
Nov 13, 2002 08:45 PM
