Maximum cylinder bore on a 1992 351w - Ford Truck Enthusiasts Forums
Old 12-17-2007, 09:53 PM
blaze42069's Avatar
blaze42069
blaze42069 is offline
blaze42069 is starting off with a positive reputation.
I have a 1992 351w f250 block and want to put it in a 91 mustang lx. I want to stroke this to a 408 with an eagle rotating assembly all forged with a main girdle and arp studs on the mains and heads with afr 225 race heads. The block I have needs a .040 over bore. I'm looking for 500-550 hp on pump gas with 10.5 cr. Will this big of a bore be acceptable for this block?? I know the older 351w's 69-70 are the stock block to have but these are the cards i'm dealt. thanks
Old 12-18-2007, 05:38 AM
HemiEater's Avatar
HemiEater
HemiEater is offline
HemiEater is starting off with a positive reputation.
.040 is fine, I would run it.
Old 12-18-2007, 06:59 PM
blaze42069's Avatar
blaze42069
Do you know the max bore on a 92 351w block that is allowable?
Old 12-18-2007, 07:43 PM
HemiEater's Avatar
HemiEater
got me ? look up some rings and see what's out there..... .040 should be just fine...
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
