Truck back fires
Old Dec 18, 2007 | 05:49 AM
JimG1098's Avatar
JimG1098
Truck back fires
Good moorning all and a happy holliday season. Have been thinking about my truck and what I may do. The truck backfires when you step on the gas.
Truck idles well and timing is correct at 10 BTDC. Truck starts well and points and cap are clean.
I have not physically traced the plug wires for reversals yet. VaCUME ADVANCE APPEARS TO BE WORKING. My thoughts are this. I am thinking of having the holly 2bbl rebuilt by a pro, ( if I can find one). Might there be any other things I should be looking at while I tale the carb out. ( 1954 f-750, 279 ci )
As a side topic, I now can put my the 54 in my garage with my 99 f-150 for the winter ( heated). A little tight, but I can still walk arround. On days I work on the truck, I pull out the 99 and move the 54 over. Loving this garage.
My wife has the garrage that is attatched to the house. All for herself. Keeps everything good!
Thanks for any info and enjoy the hollidays
Jim G
Old Dec 18, 2007 | 07:03 AM
needhelp49's Avatar
needhelp49
back fireing throw carb or exshaust a ton of things can cause it bent valve worn lobe on cam timeing
Old Dec 18, 2007 | 07:04 AM
needhelp49's Avatar
needhelp49
oh and happy holidays to you to
Old Dec 18, 2007 | 08:34 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Does it backfire contiinuously and is it out the carb or out the exhaust? If it's continuously, it's almost certainly a firing order issue (if you've recently removed/replaced the wires). It could also be a bad ignition condenser, or points that have insufficient gap. Start with the basics, the carb is not likely a problem.
If it just chuffs a couple times when you step on it, check the accelerator pump.
Old Dec 19, 2007 | 12:28 AM
lewislynn's Avatar
lewislynn
Jim G
Do a compression test first to see if it's a valve.
Are you having carburetor problems? Your carburetor could be too lean.
Take your carburetor to a shop that builds engines, like a speed shop.
You're usually better off rebuilding what you have rather than buying rebuilt.
Old Dec 19, 2007 | 05:55 PM
robertr's Avatar
robertr
JimG
If you only find the backfiring under load, one other common cause is a coil going bad. If you have another coil around that you could use, a quick try of that would be an easy means to eliminate the coil as the cause. Tune up shops can easily find such a problem by running a scope check, but the cost to do that would likely be more than the price of a coil. A bad coil will show up very clearly on a scope ignition pattern. Easier and cheaper to just try another one, and see what happens.
Food for thought anyway........
Bob in Spokane
Old Dec 29, 2007 | 07:34 PM
JimG1098's Avatar
JimG1098
Hi gang,
working on the truck backfireing. Taking all of your advise, Went to check plug wires, Can not physically trace them, they are in insulators. How can I check them, Tried to use ohm meter, cant get reading. Also tried to use trouble light, can not get it to light, I did however, get a reading on the Dist to coil secondary wire,
What is the best way to trace and check out plug wires.
Thanks,
Jim G
Old Dec 29, 2007 | 09:25 PM
rswhitmore's Avatar
rswhitmore
You should be able to trace the wires with an ohmmeter. Put the meter on the Kilo-ohm scale. The reading could be as high as 20K Ohm. If you cannot get a reading at all on a wire on the K-ohm scale, you need to replace the wires.
