Timing Question- Help Please
Old Dec 18, 2007 | 01:06 AM
Midnight88's Avatar
Midnight88
I have a 88' F-150 5.0MFI with TFI ignition, but heres the fun one, whats the timing supposed to be at, I'm missing the lovley little EPA Sticked under the hood that all manuals tells me to look at, it's a new hood missing the badge. Thanks-
Old Dec 18, 2007 | 04:49 AM
EPNCSU2006's Avatar
EPNCSU2006
10° BTDC with the SPOUT connector removed.
Old Dec 18, 2007 | 08:40 AM
95F350XL's Avatar
95F350XL
You can do 14* it will run a little better for you.
Old Dec 18, 2007 | 10:35 AM
DJdemon6696's Avatar
DJdemon6696
jep start with 12.5* if it runs good chek it at 14*
mine is at 14* and runs gr8
Old Dec 18, 2007 | 10:54 AM
dixokai's Avatar
dixokai
Any of you running them at 12-14 have to run higher octane? I was wondering if it would detonate at that? I'm gonna try it this weekend.
Old Dec 18, 2007 | 11:05 AM
red89notch's Avatar
red89notch
u wont have any issues running at 12-14 degrees. unless you consider running a little stronger a issue
should you run a higher octane with a more advanced timing? yea but if your not hearing detonation then your fine, i run 17 degress on my mustang, but i do run 108 octane
the only purpose of a higher octane is to prevent knock (detonation)
now if you plane on putting a little nitrous on the motor make sure to pull 2 degrees for every 50hp shot your running , lol sorry i couldnt help giving a little mustnag tech in there for ya
Old Dec 18, 2007 | 11:24 AM
quicklook2's Avatar
quicklook2
i put mine at 10 degrees as ford intended.
runs just fine and has all the power i need.
Old Dec 18, 2007 | 08:31 PM
EPNCSU2006's Avatar
EPNCSU2006
"u" sure about that? I run 89 octane and can't advance more than 11, maybe 12 without audible pinging.
Old Dec 18, 2007 | 08:43 PM
dixokai's Avatar
dixokai
www.fordfuelinjection.com suggests trying 12 deg. but listen carefully for detonation and then try more advanced or back it off depending on the result. I don't want to run the high octane stuff if I don't have to because I'm CHEAP!!!
Old Dec 19, 2007 | 12:30 AM
Midnight88's Avatar
Midnight88
Thanks guys, great hep, I'll Start at 10 and work my way up. Max I'll go ispobably 13 cause she's a tired old beast, 144,553 miles
Old Dec 19, 2007 | 07:53 AM
dixokai's Avatar
dixokai
Just broke in.....
Old Dec 19, 2007 | 11:16 AM
DJdemon6696
he's right mine is at 257.+++ miles and the timing is at 14 and got lots of stuff extra and still is healty
Old Dec 19, 2007 | 09:05 PM
Midnight88's Avatar
Midnight88
Hopefully if I sell my Jr. Dragster in the next two weeks I'll be building a 331 small block torque monster. By the way, i'm only askin' $3,700 for a 2001 Nervo Cogin Jr. Dragster, inquires welcome. FAST, built Raptor 3 briggs, great for the kids christmas present and I want a new motor...LOL. Thanks guys
