Sponsored by: Auxito
Girl Needs alittle Help
Old Dec 17, 2007 | 09:27 PM
pisto25's Avatar
pisto25
OK Guys...I have a 01 F150 4x2 6cyl 4.2L (or it might be a 4.6) with about 94000k on it. I got the truck in 05 and have not done anything besides oil and tires on it.......
well it all of a sudden started running rough (like it was going to stall), check engine lite on, and the battery kept dieing....so I took it to auto zone, got a new battery, and the guy said the test showed that it was misfire on 1 and 6...he told me that it should just need new spark plugs and wires....SOOOO do you think this would be something that I can do or take it to the local shop? and second is there anything else it could be besides the spark plugs?
Any information would be great!!!
Old Dec 17, 2007 | 09:54 PM
xtrford's Avatar
xtrford
I would say you are about due for a plug change...wouldn't hurt. Check your coolant level also because the 4.2's are prone to head gasket leaks if that is what kind of engine you have.
Old Dec 17, 2007 | 09:57 PM
pisto25's Avatar
pisto25
the 4.2 is what I have....would that make the CEL come on it misfire on 1 and 6?
Old Dec 17, 2007 | 10:18 PM
xtrford's Avatar
xtrford
Yup, would be good to go back to autozone and get the codes.
Old Dec 18, 2007 | 01:18 AM
LastSplash's Avatar
LastSplash
Does the 4.2 have a coil pack or is it a COP? If they have a coil pack it may be going bad, it is common for a coil pack to fire 2 cylinders at a time for a 6 cylinder cyl 1 & 6 are fired at the same time as well as 2&5 and 3&4. Also check you plug wires on 1&6 if either wire is shorted it will cause both cylinders to misfire.
Old Dec 18, 2007 | 09:21 AM
jdhudall's Avatar
jdhudall
I agree with Lastsplash it more than likely is your coil pack I had the same problem on my 2001 with the 5.4 I had a missfire on #7 at 88,000 miles and it was the coil on plug (cop) I replaced all the spark plugs but they didn't look bad! The COP is where the coil is attached to the spark plug boot right on top of the plug! The 6 cylinders use three coil packs each one runs two cylinders so I would say the coil pack that is running 1&6 is your problem! I would change all the plugs while your at it I'm sure that is not your problem but with 94,000 on the clock they are about due! You should have no problem doing it yourself as long as you have a good set of tools to work with! You will need a variaty of extentions and u-joints to get at some of the plugs!
Old Dec 18, 2007 | 09:57 AM
LxMan1's Avatar
LxMan1
Welcome to the forum Pisto25
I would try a tune up with plugs and wires. You are about due.
Old Dec 18, 2007 | 04:17 PM
pisto25's Avatar
pisto25
The coil pack is what we are going to do. Because we did the wires (which did not look bad) and it is still doing it. Should I just be able to do the one coil pack? I hope that is all that I have to do....do you think it could be something else?
Old Dec 18, 2007 | 06:44 PM
LxMan1's Avatar
LxMan1
The 6 cyl only has one coil pack. The one on my Windstar died on cyl. 2 when it went. The other 5 still worked.
Old Dec 18, 2007 | 06:46 PM
Jimmy Dean's Avatar
Jimmy Dean
Join us in the 4.2 forum.
But spark plugs are easy to change as long as ya have a ratchet.
The '01 4.2 is not prone to gasket leaks, only the 97-early 98s are. they are very rare after that point, when Ford realized they screwed up.
Old Dec 19, 2007 | 12:29 AM
jdhudall's Avatar
jdhudall
Yes I would only replace the coil pack that is bad!
Old Dec 19, 2007 | 04:01 PM
pisto25's Avatar
pisto25
Thanks guys for all your info. We did the coil pack today and it is running GREAT!!! Again I appreciate everything
