Vibration 35 MPH
Old Dec 17, 2007 | 08:40 PM
RMS94's Avatar
RMS94
Vibration 35 MPH
My ole' '94 has developed a small vibration starting at 30 mph and ending at 35 mph. I have replaced the three universal joints, truck is a short bed supercab, one universal was bad - the rolls and turned to rusty metal dirt, and had the front end aligned. The front wheel bearing were checked last year. The engine runs and idles well with like always acceleration.
Any ideas on what to check next?
Roger
Old Dec 17, 2007 | 08:55 PM
NeXtras's Avatar
NeXtras
if it seems to be coming from the front and you have the automatic locking hubs (if you have 4 wheel drive) checl those, i get vibrations because my hub is broken
Old Dec 17, 2007 | 09:33 PM
RMS94's Avatar
RMS94
My '94 is a 4x2 w/ the 302 V8 and an auto trans.
Roger
Old Dec 17, 2007 | 09:37 PM
95F350XL's Avatar
95F350XL
I know my truck front shakes in the morning untill my tires warm up. I got 36's and no steering stabilizer. I do have some play in my box that I need to take care of. Once I do that and get a stablizer it should go away. Did you try rotating your tires and see if it moves to the rear from the front? Id say balance but 30-35 is 2 slow. Usually that is U-Joint area.
Old Dec 18, 2007 | 01:18 AM
Sangetsu03's Avatar
Sangetsu03
Rotate the tires first so you can eliminate them as a source. A wheel could be out of balance, or one of the tires could be out of round, possibly due to a broken belt or mild tread separation.
Old Dec 18, 2007 | 07:46 AM
RMS94's Avatar
RMS94
The tires were rotated when the front end was aligned. No difference in the vibration was noticed after the alignment.
Roger
Jim Bark
General Diesel Discussion
Jan 18, 2014 10:09 PM
MikeRizz
Aug 26, 2013 08:11 PM
lebanontn
Aug 17, 2013 12:53 PM
JW 4x4
Jan 22, 2002 02:58 PM
FRANKR
Jul 15, 2001 07:00 AM
