Any one use comp cams???
Old Feb 7, 2001 | 06:51 PM
milfordjenings's Avatar
milfordjenings
Hey,
Has anyone on the board used comp cams p/n 66-237-4? I am planning on building my 300 instead of swapping in a v8 for now and want to use this "High Energy" cam (260H). I plan to use a holley 390 carb, offy intake, this cam (in the form of a kit with timing set, valve springs, locks and retiners and lifters along with the matching pushrods) and clifford headers.
What I am trying to accomplish is make my 78 f-250 4x4 be able to get out of it's own way. I also want to increase the rev range. So if you have experience or have driven a similar rig let me know.
MJ
Old Mar 3, 2001 | 04:20 PM
paulieg69's Avatar
paulieg69
Old Mar 7, 2001 | 10:22 AM
paulg's Avatar
paulg
I bought a Comp Cams camshaft (advertized duration of 254degrees) for my 94' EFI Ford F150. I haven't installed it yet but I did alot of research before doing so. Everyone (automechanics) I talked to said this would really give the engine some extra power. With the plans you have in mind, your 6er should haul some butt!
Old Dec 5, 2004 | 08:32 PM
Machman's Avatar
Machman
Hey Paulg, Did you ever get around to installing that cam yet? I have a stock 95 and I am looking at the same cam. Still doing research and going bananas sifting through what might be the best for me. Is your truck stock? What did your research turn up?
