Clutch Problem
Old Dec 17, 2007 | 04:16 PM
ricka475's Avatar
ricka475
Clutch Problem
On the way into work this morning I went to shift and the clutch made a pop about 1/2 way in and then would not release at all. I haven't had a chance to check much except to verify the fluid level. Just looking for thoughts on what the pop may have been and which way to proceed from here. I'm guessing I'm looking at pulling the transmission...
Thanks..
2001 Ranger 2wd SB
2.3 ltr
Old Dec 17, 2007 | 10:15 PM
Rockledge's Avatar
Rockledge
Your description is a little fuzzy. Can you physically push the pedal all the way down? Is the truck currently stuck in gear?
Old Dec 17, 2007 | 10:36 PM
ricka475's Avatar
ricka475
Sorry for being so obscure...The pedal does travel the full length, the clutch just does not release..I actually got it home by putting it in 1st gear with the engine off and then starting it...once it got up to speed ~10-15 mph I could shift it into 2nd - with a little force. Kinda weird I know but it worked. I went out to look at it tonight and nothing amiss externally. The pedal actually feels normal - just not releasing. I can shift thru all the gears with the engine off but not with it running. Hope this describes it a bit better.
Old Dec 17, 2007 | 10:46 PM
Rockledge's Avatar
Rockledge
In all likelyhood you're looking at a clutch job. I'd guess that there might be a few broken fingers in the pressure plate, or something like that.
Old Dec 17, 2007 | 10:50 PM
ricka475's Avatar
ricka475
That is kinda what I'm thinking as well...Guess I have my weekend planned already...Thanks, I'll let you know what I find..
Old Dec 18, 2007 | 03:52 PM
ricka475's Avatar
ricka475
question before I get into this on saturday...Whats the best way to remove the pilot bearing from the flywheel assuming I don't remove the flywheel itself?
Old Dec 18, 2007 | 06:51 PM
cracked block's Avatar
cracked block
I beleive you can remove the pilot bearing by filling the hole with bearing greese and drive a drift into the grease. Be sure and wear a face shield!!! But it should pop out. Good luck and keep us posted.
Old Dec 18, 2007 | 08:11 PM
Hank85713's Avatar
Hank85713
on my 94 drop the flywheel and just tap it out, dont know about the newer ones however.
Old Dec 19, 2007 | 12:31 AM
Pablo-UA's Avatar
Pablo-UA
Ricka, to pul out this bearing I made 2 small hooks, welded them together, welded a small ting and with puller screw pull it out. Some gues use big screwdriver and nock it out (sometimes broken in pices)....
__________________________________________________ _____________________
The most original way!!!
As I can see, clutch lives about 5-10 years. Fortunatly it is cheap and easy to do. That's why I like manual trannyes.
