Sponsored by: Real Truck
Axle & transfer case oils
Old Dec 17, 2007 | 04:06 PM
wagntwister's Avatar
wagntwister
I have an 04 f-250 crew cab 5.4 L auto with 4:10 rears what oil and do I need to replace the cover gaskets or is RTV ok?
Old Dec 17, 2007 | 10:29 PM
oltrucker's Avatar
oltrucker
the best is 90-140 synthetic gear lube. use the same in the transfer case. rtv is ok, but dont use to much.,,,let it set for a while until it skins over before putting it back together.
Old Dec 18, 2007 | 07:42 AM
redford's Avatar
redford
FTE Leadership Emeritus
90-140 synthetic is not correct. This from the 2004 Owner's Manual, available for download at
http://www.analogstereo.com/pdf/om/f...anual_2004.pdf
Front axle: Motorcraft SAE 80W-90 Premium RearAxle Lubricant
Rear axle : Motorcraft SAE 75W-140 Synthetic Rear Axle Lubricant
Transfer case fluid : Motorcraft MERCON ATF
Al's F-350 4X4
Dec 9, 2013 05:30 PM
cornfeed
2004 - 2008 F150
Dec 12, 2012 08:14 AM
Race4Fun82
Mar 5, 2012 05:41 AM
XmethDrums
1997 - 2003 F150
Apr 29, 2005 12:26 PM
pcmenten
Oil & Lubrication
Feb 6, 2003 06:20 AM
