Sponsored by: Real Truck
Heated Mirrors
Old Dec 17, 2007 | 08:40 AM
Green Ford's Avatar
Green Ford
Heated Mirrors
My 03' SD came without the heated mirriors. I really miss them! I see I can buy them on ebay with the turn signal and heated options. My question is because the truck din't come with them will it be a pain in the butt to put these in? More wires to run etc? Has anyone done this?
Old Dec 17, 2007 | 08:56 AM
empiretc's Avatar
empiretc
its not too bad. My truck didn't even have power mirrors, and I did the complete upgrade. you can run a separate wire that is hot w/ key on. you can also install a switch to turn the heat on and off as needed. my buddy just tapped into the power at the factory plug. only problem there, is I believe it has constant power.
Brandon_01
Nov 26, 2008 09:54 AM
bigoguide
Jan 14, 2008 03:51 PM
tims01
Oct 16, 2006 12:23 AM
Navdriver
Electrical Systems/Wiring
Jan 7, 2004 12:15 PM
mattash
Mar 15, 2002 06:20 PM
