Fluid capacities??
Old Mar 9, 2001 | 11:11 AM
kassonb's Avatar
kassonb
Fluid capacities??
I have a used 1990 F-150 4.9 4x4 5speed . I didn't get the owners manual :-( and I would like to know what all the fluid capacities are. Anyone know
I would like to go to all synthetics - any cons???
Thanx
Old Mar 9, 2001 | 12:34 PM
paulg's Avatar
paulg
Fluid capacities??
[font size="1" color="#FF0000"]LAST EDITED ON 09-Mar-01 AT 01:40 PM (EST)[/font][p]>I have a used 1990 F-150
>4.9 4x4 5speed .
>Anyone know
>Thanx
Engine oil capacity is 5quarts.
Transmission oil capacity is 4 quarts.
Differential fluid capacity is 3 quarts.
Radiator capacity I believe is 3 gallons.
As for changing to synthetics from non-synthetics is something of a large gap. Basically you don't want to go from non-synthetics to synthetics as the synthetics will clean the engine thoroughly and remove any 'false's seals, especially on an engine with high mileage. As for improving protective performance, this can be debated all day. I am under the impression synthetics provide better protection but not by much. As long as you change your truck's oils regularly and flush the radiator at regular intervals it will do just fine! Also regular oils are cheaper than synthetics. I understand though you want the best for your baby!
Hope this helps! :-)
1994 Ford F150
300-6
Highly Modified and more to come!
Old Mar 9, 2001 | 10:08 PM
kassonb's Avatar
kassonb
Fluid capacities??
Yes this helps.
Know what the transfer case holds?
Thanx much :-)
Old Mar 10, 2001 | 12:51 AM
hood's Avatar
hood
Fluid capacities??
paulg....
Correct me if i'm wrong, but i thought that the 4.9L took 6 quarts of engine oil. That's what i've been putting in mine since 1981. hmmm...
1981 F-150 2WD STYLESIDE P/U
4.9L 1 BBL CARB
C6 AUTO
2.73:1 LIMITED SLIP REAR AXLE
STABILIZER BARS FRONT & REAR
6100 LB GVWR PACKAGE
ORIGINAL OWNER
193,000 PLUS MILES
100% STOCK & UNREBUILT
BUILT FORD TOUGH!!!
Old Mar 10, 2001 | 07:56 PM
tye's Avatar
tye
Fluid capacities??
My 300 takes 6 quarts too, with a filter change.
1991 F250 4x2
300 I6 5speed
Old Mar 11, 2001 | 11:56 AM
traildawg's Avatar
traildawg
Fluid capacities??
Usually they don't account for the extra quart of oil in the filter when they state the oil capacity in manuals. Seems kin of strange to me, but that's how they do it.
TrailDawg
https://www.ford-trucks.com/dcforum/User_files/3aaa4bac6f539876.jpg
1993 F150 2WD
4.9L-Auto
Pro-Comp Stage-2 6" lift
Auburn Pro-Series Diff. w/4.30:1 gears
35x12.50x15 General Grabber MT's
http://www.geocities.com/ProjectTrailDawg
Old Mar 11, 2001 | 06:18 PM
classicfordluvr's Avatar
classicfordluvr
Fluid capacities??
One of the best investments you'll make is a manual for your truck. My Haynes was 16 bucks at Canadian Tire and is a very good read. Page 1-2 gives capacities as follows:
Engine oil (with new filter) - 6.0 qts
Cooling system (inline 6 only) - 14 qts
Manual trans: (US pints)
Ford 3-speed - 3.5
Ford SROD 4-speed - 4.5
NP435 4-speed with extension - 7.0
NP435 4-speed without extenstion - 6.5
Warner T-18, T18B, T19B 4-speed - 7.0
Mazda 5-speed - 7.6
ZF S5-42 5-speed - 6.8
Transfer Case:
NP 2-speed part-time - 6 to 6.5 pints
Warner 13-45 Full-time - 6 to 6.5 pints
Borg Warner 13-56 manual and electronic shift - 2 US quarts
Borg Warner 13-56 with PTO - 6.1 US quarts
Automatic Transmission:
C4 - 9.6 to 10.0
C5 - 11.0
C6 - 11.7 to 13.5
AOD - 12.0
E4OD - 16.2 to 17.7
Differentials: (US pints)
Ford 8.8 and 9.0" - 5.5
Ford 10.25 - 7.5
Dana 44IFS, IFS HD and 50IFS front - 3.6 to 4.0
Dana 60 front - 6.0
Dana 60, 60-5, 61-1, 61-2, and 62 - 6.0
Dana 70 - 6.5
Dana 70 HD - 6.0 to 7.5
Hope that helps you out!
Chris in Canada
74 Gran Torino Brougham 351W 2V/C6
84 F150 2WD 300 I6/NP435 4-spd/3.08 rear
Old Mar 12, 2001 | 05:25 AM
kassonb's Avatar
kassonb
Fluid capacities??
Yes - that helps a lot.
I purchased the original shop manuals but believe it or not the capacities are not in there. These are the original 1990 service manuals from Ford !! Seem to cover everything else in detail.
Thanx. :7
Old Mar 12, 2001 | 02:43 PM
classicfordluvr
Fluid capacities??
Old Mar 13, 2021 | 10:23 AM
Daniel Robert Mejia's Avatar
Daniel Robert Mejia
Power steering?
I know I should fill to the dipstick indicator. But does anyone have the capacity spec on the power steering system, if I were to do a complete flush?
I plan to put Type F after I rebuild the pump.
Old Mar 13, 2021 | 09:48 PM
FlyJSH's Avatar
FlyJSH
Veteran: Navy
I don't know the true capacity, but when I did a good flush, I bought a gallon. flushed until good and clear, filled, and had over a quart left over. It got rid of the howl at full stop too.
nnero
Feb 2, 2009 06:03 PM
hndamxmn
Nov 29, 2008 04:44 PM
RustyFord88
May 21, 2007 03:03 PM
PigFarmer
Oct 23, 2002 07:47 AM
