460 crankcase breathers?
Old Dec 16, 2007 | 11:33 PM
joditruck's Avatar
joditruck
I have a mildy built 460 with Ford cast aluminium valve covers. I have not drilled holes for the crankcase breather or pcv yet. Is it better to run a PCV valve by itself or with an open crankcase breather? Or should I just run one or two breathers on the valve covers? Thanks for the help,
Sam
Old Dec 17, 2007 | 05:33 PM
Mil1ion's Avatar
Mil1ion
I don't have emission stesting so I let out a vented fill cap for breather.
PCV definitely have.
Old Dec 19, 2007 | 12:17 PM
mcdonaldm's Avatar
mcdonaldm
you can do it either way. either run 2 breather caps one on each cover or run a pvc with breather on other valve cover.
most train of thought is that a pvc system is better way than just open breathers. the pvc system creates a vacuum in the crankcase that helps the rings seal better and also the side benefit of creating a little extra hp, not much, maybe 2 - 5hp max, but every little bit helps. also a little bit of help for the enviroment also.
if possible i would run a pvc system. not hard to hook up and a bit of free hp benefit too.
rgds
Mike
Old Dec 29, 2007 | 09:06 AM
werneil's Avatar
werneil
pcv in one rocker cover and breather in the other is the way to go,
breather can be open or connected to the air cleaner depending on emisions
neil
OFF 59
13
May 31, 2012 10:22 AM
dwrestle
Nov 18, 2011 12:20 AM
Ryan85
Jun 12, 2011 02:07 PM
02FX4Dude
15
Jul 6, 2005 11:27 AM
JoeBoost
May 22, 2003 10:56 AM
