(EMERGENCY) brake question.
Old Dec 16, 2007 | 10:12 PM
duback66's Avatar
duback66
Is there suppose to be a brass washer between the front brake caliper and the block on the hose on a 96" f150? I have a leak and have a brass washer on the back side of the bolt that goes through the hose block but not between the caliper and the block. I need to drive the truck to work in the morning.
Old Dec 16, 2007 | 10:16 PM
95F350XL's Avatar
95F350XL
Yes there is supposed to be brass washers on both sides. I knew a mechanic that didnt like to use them, said they leaked. Never had that prob. Try to tighten it up a little bit. Dont go crazy with it.
Old Dec 16, 2007 | 10:37 PM
duback66's Avatar
duback66
Do you mean try to tighten it without the washer?
Old Dec 16, 2007 | 10:42 PM
85F_150driver's Avatar
85F_150driver
either try tighten a little more or switch the washer to between the block and caliper.
Old Dec 17, 2007 | 04:39 AM
EPNCSU2006's Avatar
EPNCSU2006
Those are sealing crush washers. It won't seal properly without one on each side of the block.
