What kind of conversion kits are available? I have on in there now that is real screwy and think i need to yank. I believe its a Mr.Gasket kit- H pattern 3 speed.
I had the MR. Gasket shifter. Tossed it in the garbage. I got a direct fit shifter from Hurst. I ordered it through a local truck place, but it can be ordered through Summit Racing as well.
Hmm, never saw the direct fit Hurst on summit, will have to go back through and recheck. I am personally considering the TCI as well. But may go the Hurst route now. My dad had a hurst shifter in his Chevelle and loved it.
I searched assuming you are refering to your 77 f100 and I beleive my shifter is the same part in my 73 anyway:
I also have the Mr Gasket/B&M shifter in my truck and have had a lot of problems with it, such as the shifter falling thru the floor almost 2 the road, and its very sloppy and constantly needs adjustment. and the hurst kit is also available from Jegs for a cheaper price
Yes, like tractor boy says install kit has linkages and the shifter bolts to a bracket that is only in install kit. W/O install kit shifter is basically useless
