1978 - 1996 Big Bronco
96 Bronco rear window
Old Dec 16, 2007 | 07:13 PM
Broncobudy's Avatar
Broncobudy
My rear window started to go up crooked and I had to pull the passenger side up from time to time to get it to go up evenly, but am not able to get it all the way up on the passenger side. What is wrong?
Old Dec 16, 2007 | 07:23 PM
andym's Avatar
andym
Broken or detached regulator arm. Take it apart and check it out.
Old Dec 22, 2007 | 09:07 AM
Broncobudy's Avatar
Broncobudy
Fixed. The arm had come out o a socket that slides in the tray just below the window. Just had to pop that back in and it worked fine. Thanks.
Old Dec 23, 2007 | 08:58 PM
Broncobudy's Avatar
Broncobudy
Unhappy
After fixing it once, the arm keeps popping back out of the plastic holder in the track. Do you know where I can buy one of these?
Old Dec 24, 2007 | 01:03 AM
andym's Avatar
andym
If the plastic bushing is worn out, then any Ford dealer can give you the part. If Bill (numberdummy) shows up, he can give you the part number. That part was used on every Ford vehicle for about 50 years. Any dealer will have one in stock and know what you're talking about.
If the track is worn, then I don't know if you can get one without buying the window. Try the usual places online, the dealer, and the junkyard, probably in that order.
Old Dec 24, 2007 | 06:49 AM
Broncobudy's Avatar
Broncobudy
Red face
It is the plastic piece that is worn, so maybe I am in luck. I will let you know what happens. Thanks.
Old Dec 24, 2007 | 09:45 AM
Broncobudy's Avatar
Broncobudy
Unhappy
OK, I just came back from the dealer and they were worthless. Couldn't give me a part number and did not have anything in stock. Best guess is the plastic part comes with the rail that attaches to the bottom of the rear window. The local pick and pull did not have any used Broncos in the lot.
Old Dec 24, 2007 | 12:45 PM
andym's Avatar
andym
You have idiots working at your dealership then.
I'll message Bill and see if he has the part number.
Old Dec 24, 2007 | 03:12 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I can't believe the dealer didn't have this window roller...because this little charmer fits every Ford car & truck from 1976 up. It's also a part that breaks regularly.
It's made of plastic with a metal threaded stud attached.
The stud bolts to the end of the regulator arm, the squarish roller fits into the window channel that bolts to the glass.
What happens is the stud pulls out of the plastic portion of the roller.
D6AZ-5323240-A .. Window Roller / Ford suggested retail price: $7.87
There's a couple of other things that also could be the problem.
On each side of the glass, where the window channel bolts go through it, are two plastic spacers and retainers.
One inner and one outer per bolt. These have been around since 1979, and also break regularly.
2- D9AZ-54234A44-AA .. Spacer / Ford retail price: $2.81 each
2-D9AZ-54234A46-AA .. Retainer / Ford retail price: $2.77
I'll betcha if you give these parts number to the idjit behind the part counter, they'll have all these little charmers.
The rollers are stocked by every parts store in the US, so you need'nt bother the local parts idjit. Dunno if autoparts stores carry the other parts.
Old Jan 31, 2008 | 04:59 PM
Broncobudy's Avatar
Broncobudy
Talking
Just to follow up. I went to the dealership with the part numbers and the guy found it in zero flat. Thanks. I installed the part and the window works like nicely.
Old Feb 19, 2008 | 12:11 AM
acctx's Avatar
acctx
whats fellas, josh here i have a 95 FSB with a bad rear glass motor or switch. My question is there any way tho get the tailgate open or is there another way to get that windo down. ONe more if the window motor is out can i get to it without opening the gate? any help appreciated.
Old Feb 19, 2008 | 01:40 PM
aurgathor's Avatar
aurgathor
It's not easy, but you can open it even with window up from the inside after removing the carpet and the cover.
Old Feb 19, 2008 | 03:52 PM
benshere's Avatar
benshere
Lmc
Look at the LMC trucks catalog for broncos online. They show all those parts. I bought a kit and OEM bracket to mount the swing tire inside. If you cant get the dealer educated, try LMC (Lenexa, Ks.)
