engine block heater
Old Dec 28, 2007 | 08:37 AM
PLC7.3's Avatar
PLC7.3
Big Native.... check the info below....
First make sure the BH red power plug is in the BH, then do a continuity test with a meter on the main plug wires at the grill. If there is no continuity check the wires for breaks just behind the 120V plug. Pull on the wires and you can see the break as the shielding gets smaller, cut off the end. If the 2 power wires now have continuity through the BH just replace the 3 prong plug.
Old Dec 28, 2007 | 12:13 PM
greythorn3's Avatar
greythorn3
usually when you plug in your block heater if you do it slow you will see small sparks at the extension cord
Old Dec 28, 2007 | 01:32 PM
deanzawistowski's Avatar
deanzawistowski
does my 94 IDI turbo come stock with a block heater?
Old Dec 28, 2007 | 06:46 PM
Dave Sponaugle's Avatar
Dave Sponaugle
In northern areas I think it was something like a standard option.
I think it was also part of the heavy duty heating and cooling package.
Why yes, that is an option, but if you get this package, that comes with the package.
Most auto companies like to use packages instead of giving you exactly what you want.
Old Dec 28, 2007 | 08:11 PM
deanzawistowski
is the plug for it on the passanger side of the truck, kinda under the headlight and by the bumper?
I was wondering what that thing was
so with the stock block heater how long can i leave it plugged in?
Old Dec 29, 2007 | 01:18 AM
archangel's Avatar
archangel
Well, the book said three hours well below freezing should give you a fast easy start, and it does.
Old Dec 29, 2007 | 11:07 AM
Dave Sponaugle
You can leave it plugged in 24/7 if you like.
But do be aware that block heaters are available from 650 watts to 1500 watts at most parts places.
If you happened to have a 1500 watt heater plugged in for 7 days, you might have to morgage the house to pay the electric bill.
Also if you have snow or ice on the ground and notice it is melting away from the extension cord you are plugged into, the cord is not big enough as far as conductor size goes.
