Running too cool
Old Mar 15, 2001 | 05:12 PM
brown 4x4's Avatar
brown 4x4
Running too cool
My truck isn't heating up quite like it should. On cool days, it will run 160-165 degrees tops. If I cover half of the radiator with cardboard it heats right up to where it should be. I don't think it's the thermostat since I've replaced it twice thinking that was the problem. Any suggestions?
1986 F-150 4x4 300 I6 NP435
Old Mar 15, 2001 | 11:13 PM
classicfordluvr's Avatar
classicfordluvr
Running too cool
I've heard of this problem before, and the answer in the past was the thermostat was changed and installed backwards. It sounds silly, but this is the most common answer to the problem I've heard of. Make sure the long end goes into the engine block ... the more cone shaped side goes into the T-stat housing. My manual only lists two other possibilities ... a faulty temperature guage and a faulty thermostat. Check to make sure it's oriented correctly. Don't feel dumb if you did happen to put it in backwards ... I've heard of mechanics doing it too.
Chris in Canada
74 Gran Torino Brougham ... the toy
84 F150 2WD ... the driver
Old Mar 16, 2001 | 10:10 PM
warreng's Avatar
warreng
Running too cool
On the back of the block there is a sensor that connects up to the temperature guage, it might be going out. i had something simular happen to the sensor for the oil presure where i thought i had my oil pump going out. make sure you can locate that piece first, its a tight spot.
Warren from Tx
ford F150 2WD 300 I-6
Nice Truck, no money to specialize.
Old Mar 18, 2001 | 06:18 AM
rabbit stu's Avatar
rabbit stu
Running too cool
I agree. Check the wiring and the sensor.
I had an low oil pressure indication that turned out to be just a dirty connection at the sending unit.
Old Mar 20, 2001 | 11:52 AM
Bob_VT's Avatar
Bob_VT
Running too cool
Thermostats wear out. They stick open. Change to a fresh thermostat in addition to checking all your wires. When was it changed last? It is an annual maintenance thing to change the thermostat with me along with the worn out antifreeze.
Old Mar 20, 2001 | 05:36 PM
brown 4x4's Avatar
brown 4x4
Running too cool
Thermostat was replaced in December. I added a mechanical temperature guage a couple weeks ago (Yes that is a tight place), which also reads low. It will heat up like it should if I cover the radiator, but then it overheats if I have a strong tailwind.
Old Mar 21, 2001 | 12:12 AM
PAUL_2's Avatar
PAUL_2
Running too cool
Let me ask you this , What temp thermostat do you have installed ? If its a 160 deg , then its running where it should be . Is the problem you are not getting enough interior heat ?
Old Mar 21, 2001 | 08:37 AM
haleakala's Avatar
haleakala
Running too cool
I thought others have said the 194 deg stat is the correct one. Which is right 160 or 194?
Old Mar 21, 2001 | 10:02 AM
PAUL_2's Avatar
PAUL_2
Running too cool
Different engines require different temp thermostats . Efi engines should have the 192 Deg thermostats . Older carberated engines can use thermostats with lower temps such as the 160 to 180 deg range .
Old Mar 21, 2001 | 08:55 PM
olstinker's Avatar
olstinker
Running too cool
parkland
General Diesel Discussion
Nov 10, 2013 11:45 AM
bowesmobile
Oct 31, 2012 04:05 PM
4x4lugnut
Oct 7, 2012 02:48 PM
PastorPaul
17
Apr 28, 2011 08:31 AM
handsomerob
17
Jan 20, 2008 09:23 PM
