1994 ranger cold
Old Dec 25, 2007 | 09:23 AM
Hank85713's Avatar
Hank85713
I run a disconnected IAC and np you should not have idle at 1500. Thats why I disconnected mine (tried to replace 2x same results) Went to a shop and we spent about 3 hrs going thru codes and wiring books and finally it came out that there is a broken wire in the IAC circuit someplace. No I do not get an CE light have been running it this way for 100K or so, I also have the cooling issue but I just put a paperbag down in front of the rad so I dont have to take the grill apart. Mine would be hot till I hit a cold place while driving and it would drop down. Thats with an old as well as a new Tstat. Yes flush and put in new to be safe, I dont know about the core plugging as the heater will drive you out, mainly run it at the blue-red area after it heats up. truck currently has 250K on it, did replace the radiator and the water pump at around 180K (slight rad leak). Also I had guage probs and had to replace the sender and then later had to tighten the clip on it but other than that no problems.
Old Dec 26, 2007 | 10:38 PM
mblatz's Avatar
mblatz
at idle cold my truck runs 2000 and down to 1500. i'm waiting on a code reader so i can find out what the hell is going on with my engine. damn computers!
Old Dec 27, 2007 | 11:25 AM
Lead Head's Avatar
Lead Head
On my ranger, when the IAC decides to work, if i unplug it, the engine dies.SoI don't know how your enigne stays running.
Old Dec 27, 2007 | 11:54 AM
Hank85713's Avatar
Hank85713
I ran the throttle screw in till it idles ar around 800-1000 rpm and it will drop to 750 or so with the ac on. just hold the throttle open a little to see if it stays runnin when you unplug, and if it does tun the screw in some.
Old Jan 20, 2008 | 12:08 PM
mblatz's Avatar
mblatz
finally got reader
I finally got my code reader and so far i get codes 522, 565, and 157. i am a littel confused about 522 because i didn't have my truck in gear for any of the tests. would these codes give me the trouble with the engine? what would it do?
Len-Dogg
15
Oct 3, 2019 08:53 AM
Builtihtuff
3.8 & 4.2L V6
Apr 2, 2012 02:53 PM
Taumac
Mar 5, 2012 08:15 AM
77300i6
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Sep 27, 2007 01:26 PM
Big John Hance
Jul 29, 2007 09:32 PM
