chip does not like intake
Old Dec 15, 2007 | 11:47 PM
pwmp16's Avatar
pwmp16
I got a 2006 F-150 5.4. It has edge chip and works great. Got 2 to 3 mpg to gal additional. Installed a aem brute force intake and now get the p061 code along with p2106. I know the p061 is a H02 bank 2 sensor 3. Has any one had this problem. Any insight would be lots of help.
Old Dec 16, 2007 | 12:13 AM
wreedZ71's Avatar
wreedZ71
who level are you running the edge on?
Old Dec 16, 2007 | 12:55 AM
pwmp16's Avatar
pwmp16
it throws the codes on all three levels and puts the truck in safe mode. Edge says the conflict the cai and edge to the h02 sensor
Old Dec 16, 2007 | 02:07 AM
86F150302's Avatar
86F150302
Yea the edge and a CAI makes it run to lean. Put the stock intake back on.
Old Dec 16, 2007 | 09:28 AM
DaMole's Avatar
DaMole
Well not all CAI's run them lean. I have not heard of the AEM doing it either. When you put the intake on did you disconnect your battery for a couple of minutes and hook it back up? That would reset the computer to allow it to relearn the airflow.
Old Dec 16, 2007 | 07:25 PM
pwmp16's Avatar
pwmp16
well my issue seems to be fix for now. I unhook the battery cables and reconnect after a few minutes. Crank the truck and let idle in stock. Then switched to level 2 and drove the truck. Went a mile and truck threw the codes. Also fail safe mode. Put the truck in nuetral and shut it off and the recrank. It happened 3 different times and then quit. Drove approx 55 miles today and no more problem. Edge techs said I neede to train the ecu and guess that did it. Thanks for the advice
Old Dec 16, 2007 | 08:22 PM
DaMole's Avatar
DaMole
Thats great. I am glad you got it fixed. It is just as they told you. Anytime you mess with airflow in the engine you need to disconnect the battery to reset the computer. Then give it a little bit of time to relearn the new airflow.
Old Jan 21, 2008 | 06:49 PM
dfishrmn88's Avatar
dfishrmn88
Just read this thread. Would this apply to changing to an AEM panel filter from stock?
I have the Edge and it felt like it was running a little rough after I put the AEM in today.
Old Jan 21, 2008 | 07:09 PM
f150v602's Avatar
f150v602
my 04 doesnt like my cai either. im running the diablosport programmer and a brute force intake. ive changed from stock to the cai 3 times now and ive thrown lean codes everytime i put the cai on. no matter what tune is in the truck and ive even changed the mass air flow settings according to diablo to comensate for the higher airflow. still throwing codes. gettin mad at it too. i might just sell all my aftermarket stuff and put the money towards a down payment on the 09
Old Jan 21, 2008 | 09:08 PM
DaMole's Avatar
DaMole
It does not hurt anything by unhooking the battery (reseting the computer). I would give it a try then see if you see any difference in the next couple of days.
Old Jan 21, 2008 | 09:10 PM
DaMole's Avatar
DaMole
Did you try reseting the computer by unhooking the battery? Sometimes the simplest things can be the best fix.
Old Jan 21, 2008 | 09:32 PM
f150v602's Avatar
f150v602
i tried it once before but its been a while. i plan on trying it again but this time im gonna install the original tune back into my ecm. and i need to update my programmer again. then unhook the battery for a while and install the tune again with the updated specs. maybe then everything will work right.
Old Jan 22, 2008 | 01:11 AM
pwmp16's Avatar
pwmp16
hey guys just try to retrain the ecu to accept the cai. Mine still through the lean codes after resetting the ecu. Try this when it throws the code cut the truck off in nuetral and recrank and clear the codes. Mine did it about 3 times before it accepted the cai. I do not believe they are running lean cause mine threw a rich code when i did not let it warm up when it was 30 deg outside.
Old Jan 22, 2008 | 02:28 AM
f150v602's Avatar
f150v602
hmmmm thats intersting. its about 30 out right now. im gonna try it tomarow. thanks for the tip
Old Jan 22, 2008 | 06:35 PM
Brolli's Avatar
Brolli
maybe you should try a chip with a custom tune. sounds like your all running preset tunes.
Sgt93
6.7L Power Stroke Diesel
Feb 5, 2018 12:48 AM
fishman002
Nov 10, 2013 09:51 AM
fishman002
Nov 6, 2013 01:04 AM
rock2610d
Modular V8 (4.6L, 5.4L)
Mar 18, 2013 07:44 AM
Fastback460
Feb 15, 2013 06:44 PM
