78 ford heating problems
Old Dec 15, 2007 | 11:38 PM
boss42965075's Avatar
boss42965075
I have a 78 Ford Step-side truck I replaced the heater core and the radiator and also the thermostat. Im having a problem when the heater fan is on high there is cold air but when I have it on low there is some heat coming out of it. Any good pointers??
Old Dec 15, 2007 | 11:58 PM
Mil1ion's Avatar
Mil1ion
No Stepside on Ford's (GM term) .....Ford = Flareside
Topic:
Once the engine is at normal operating temp... feel both heater hoses.
They should be really hot.
If they aren't you have a flow problem.
(hoses hooked up backwards)
What temp value T-stat did you install ?
195*F...... I hope
Old Dec 16, 2007 | 12:34 AM
blakeusa's Avatar
blakeusa
Check with defrost mode
Just repaired mine/or my sons- after taking it apart i found the previous hack removed the thermastat.
Check that thermastat is installed with valve facing motor- long part
Check that the inside air vents are not clogged with debris. *removed a mouse house and a 1' pile of debris.
Make sure you have enough liquid/coolent to make the system work
If the fan is blowing on all speeds its working- unless clogged
Also test in Defaust mode as the lower vents may be clogged- if driving you may also get cold air in if the vents are not closed well.
Also as Million says use a 195 stat if you want heat. Im in CT and need all the heat I can get.
Regards
Old Dec 23, 2007 | 09:42 PM
boss42965075
Is there a certain way to hook up the heater hoses and if there is , what is the correct way
Old Dec 23, 2007 | 09:43 PM
boss42965075
I Just Put A New 180 Degree Thermostat In It Too.
Old Dec 23, 2007 | 09:46 PM
Mil1ion's Avatar
Mil1ion
It should be 195*
These engine were designed to run at 200-210* F
Too cool and they will be less efficient can wear faster.
Yes the hoses run a certain way.
which engine
Old Dec 23, 2007 | 10:30 PM
boss42965075
It has a 460 engine new heater core thermostat and 4 row radiator but still no heat. Which way do the heater hoses go?
Old Dec 23, 2007 | 10:56 PM
Mil1ion's Avatar
Mil1ion
Old Dec 23, 2007 | 11:35 PM
boss42965075
I have the hoses hooked up correctly From wht it shows here. Now Im really stumped.
Old Dec 24, 2007 | 06:15 AM
ranger429's Avatar
ranger429
What state do you live in?
A 180 is more of a summer T-stat, you should change that out for a 195. Have you let the truck run for a bit and felt the heater hoses? They both should be very hot to the touch. Post up from there and it gives us a better idea as to what to look for.
Old Dec 24, 2007 | 08:49 AM
Pro-Street/StateTK's Avatar
Pro-Street/StateTK
Boss42965075
Some of these trucks have a garden style turn off in one heater hose, to
keep the flow out of the cab in the summer, mostly on (AC)trucks, but I have
ran across the turn off on some non(AC) trucks!
P.S. the water in the hose still gets a little warm! Also make sure the water
valve is opening, it works off a cable.
Wally Womack
Old Dec 25, 2007 | 12:41 AM
boss42965075
I ran the truck today for about 10 miles. Temp. gauge went to the r on normal and when I got home I felt the hoses one is alot cooler than the other.I have in a new heater core and radiator and thermostat. Is there a flow problem now? If so where do I start??
Old Dec 25, 2007 | 12:43 AM
boss42965075
I just put in a new waterpump yesterday too.
Old Dec 25, 2007 | 09:38 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Pro-Street/StateTK
Some of these trucks have a garden style turn off in one heater hose, to keep the flow out of the cab in the summer, mostly on (AC) trucks
The following is correct for A/C trucks, the shut off valve was only used F500 and larger trucks. Someone added the shutoff valve.
Wally Womack
1973/79 F100/350 with factory A/C.
D4AZ-18495-A .. Vacuum (Operated) Heater Water Valve (Motorcraft YG-136)
This valve is plastic/metal, splices into the heater hose at the right rear passenger side of the engine compartment. On the top of the valve is a nipple for the vacuum hose.
This heater water valve was a POS from day one, and has been on Ford's "All Time" parts best seller list since 1974. Many have been removed, or something subbed in place of it.
BTW: Also fits 1971/1990 Ford Crown Vics / Lincoln Town Cars / Mercury Grand Marquis without ATC.
Old Dec 27, 2007 | 09:00 PM
savage066's Avatar
savage066
the heater core isn't allowing coolant flow. try reversing the hoses and see what happens. both hoses should be hot...if one is cold, you can assume that there's no coolant in it (at lease not coolant that is in circulation). if not, your heater core might be blocked, new or not.
