Cruise/ ABS
Old Dec 15, 2007 | 09:59 PM
THE KING's Avatar
THE KING
Cruise/ ABS
Hey, Ive got some driving that im going to be doing now in my bronco and i would like to get my cruise control back up and working. Now earlier this summer ive done a little investigation in why its not working. I tested to see if i had resistance in the sensors on the rear axle and i didnt have any. So i went ahead and bought a new sensor, put it in and nothing. Before i go spending anymore money can someone tell me where to start. Is this a common problem? Is my Cruise Control not working due to my abs. I should also add that i redid my breaks with new rear drums pads and hardware kit, and the front rotors turned and new pads. I also cleaned up the sensor wheel inside the hub. Im thinking towards the lines of my front speed sensors are bad. What do you guys think..........
Old Dec 15, 2007 | 10:02 PM
quicklook2's Avatar
quicklook2
does horn work?
what year truck?
Old Dec 15, 2007 | 10:03 PM
THE KING's Avatar
THE KING
What would the horn have to do with it, and yea it works? My sig tells ya
Old Dec 15, 2007 | 10:05 PM
quicklook2's Avatar
quicklook2
thanks for posting the year.
if you have an airbag than the clockspring may be bad and the horn would also not work.
Old Dec 15, 2007 | 10:07 PM
THE KING's Avatar
THE KING
Ok its a 1995 Ford Bronco, 351 No i have a horn still, so obviously thats not the problem.
Old Dec 16, 2007 | 07:20 AM
subford's Avatar
subford
4WASB 1995 Bronco
Are you saying that your ABS does not work? If so post the ASB codes and maybe we can go from there.
Here is how to get the codes if you do not know how.
Light Flash Technique
1. NOTE: If 12V test light is not available, the amber ABS warning light also flashes during this test.
Locate test connector in the engine compartment and install 12V test light between Pin C and E.
2. With the ignition off, jumper Pin E to B.
3. Turn ignition switch to RUN position.
4. Remove jumper between Pins E and B after 5 seconds.
5. Count light flashes of test light or amber ABS warning light.
Old Dec 16, 2007 | 07:28 AM
subford's Avatar
subford
Cruise Control 1995 Bronco
Have you taken it in to a Ford dealer for the switch mod for the fires?
If not do that first, the switch on the MC may be bad, let them change it for free.
Old Dec 16, 2007 | 11:11 AM
quicklook2's Avatar
quicklook2
the horn may still work and the clockspring may be bad.
do what subford posted.
good luck.
Old Dec 16, 2007 | 11:49 AM
THE KING's Avatar
THE KING
Yea i did that before but i dont remember wut i got. Il have to do that again, also its already got the recall done on it. Let me fool around with that a bit and see wut i come up with. thanks
Old Dec 20, 2007 | 01:09 PM
THE KING's Avatar
THE KING
I ran the codes today, Flashed 7 times, In my Chiltons Book it states "No Isolate Valve self Test" What does this mean? Thanks
Old Dec 20, 2007 | 01:24 PM
THE KING's Avatar
THE KING
Sorry i just read further and that chart was for a 89, i also had my father help me because running form the engine compartment to the drivers seat and not missing any lights is near impossible lol, i ran the test again and it was code 27. had two flashes then a pause then 7 more flashes after that. I dont have a chart for this. Again im running the ABS Self Test on a 95 Ford bronco with a 351. Thanks
Old Dec 20, 2007 | 02:45 PM
subford's Avatar
subford
PINPOINT TEST G: REAR AXLE OUTLET SOLENOID CONCERN DIAGNOSIS (CODE 27)
27 -- Open circuit to valve block or anti-lock brake electronic control module, open or shorted valve coil or internal anti-lock brake electronic control module damage.
Affected Circuit(s)/Electrical Component(s)
Description
Code 27 is generated by the anti-lock brake electronic control module's detection of an open or shorted Circuit 510 (T/R) and by an open or shorted outlet rear axle valve coil or an open or shorted driver in the anti-lock brake electronic control module.
Possible Contributing Component/Vehicle Wiring Concerns
Description
Intermittent open Circuit 510 (T/R)
Terminal backout in anti-lock brake electronic control module connector Pin 27
Terminal backout in valve block connector Pins 1, 4 and 3
Open or shorted outlet rear axle valve coil
Open or shorted driver in anti-lock brake electronic control module
Old Dec 20, 2007 | 03:06 PM
THE KING's Avatar
THE KING
Hmmm Interesting. In laymons terms please hahaha. I Kinda get wut its saying, My Control Module is bad?
Old Dec 20, 2007 | 03:28 PM
subford's Avatar
subford
Verify terminals at Pins 17 and 27 are clean and secure in the anti-lock brake electronic control module harness connector.
Measure resistance between Pins 17 and 27.
Is reading between 3 and 6 ohms?
Old Dec 20, 2007 | 03:32 PM
THE KING's Avatar
THE KING
Ok i will. Thanks alot for our help.
