Sponsored by: Real Truck
trans problems
Old Dec 15, 2007 | 08:58 PM
countrysF250's Avatar
countrysF250
trans problems
01 Psd F250 trans not acting right shifts feel fine but wants to jump around finding gears alot and tachs out to far going into some gears any suggestions
Old Dec 16, 2007 | 06:38 AM
countrysF250
Does anybody have any suggestions
Old Dec 16, 2007 | 08:12 AM
msgtg's Avatar
msgtg
I'd look for loose vacume lines. Not a tranny guy so after that I'm out of suggestions.
Sorry Pal
Joe
Old Dec 16, 2007 | 10:06 AM
rbaker6336's Avatar
rbaker6336
could be something to do with the mechanical diode in the 01 transmissions,can't remember all the symthoms
where's mark he always has the answers to these questions
Old Dec 16, 2007 | 10:31 AM
dougger222's Avatar
dougger222
The tranny is doing this in the F250. From 40-65mph it jumps in and out of OD a bunch. No tranny light either so guessing it's internal. My mechanic took out the syn fluid and installed new syn fluid and it's doing the same thing. When the original tranny failed it skipped second gear. This one has 167K miles on a $2K Ford rebuild. When towing it's never left OD and now that seems to be the gear thats slipping.
Been driving this way for about 2K miles but the fuel mileage is way down due to higher than normal rpm's at cruising speeds.
I see your running a chip/lift/large tires. These all can cause to a premature tranny failure. What are your miles and whats the history of the truck (fluid changes, original tranny, miles).
Old Dec 16, 2007 | 10:37 AM
rbaker6336's Avatar
rbaker6336
did you check for a short in the OD wire in the column seems to be a problem in these trucks
Old Dec 16, 2007 | 02:44 PM
countrysF250
the truck has 84,000 on it now first rebuild was at 27,000 then again at 74,000 as far as the history of the truck regular fluid changes and since the second rebuild i reall take care of it and as easy as i can be on it P.S. not much towing with the truck just mostly a daily driver street truck the chip stays of for the most part
Old Dec 16, 2007 | 05:48 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
This must come under the heading, "Any suggestion is better than none."
What would a vacuum line do with a diesel engine and an electronic transmission? There are no vacuum lines!
Does the overdrive switch and light work? If so, and it isn't flashing, then its going to be more difficult to find the problem.
With no data to go on, such as a code, my guesses are a bad TRS or TPS. That's Transmission Range Sensor and Throttle Position Sensor. The TRS is on the driver's side of the trans, and the TPS is on the accelerator pedal.
Old Dec 16, 2007 | 06:05 PM
countrysF250
thanks guys i drove it again today and at times it goes through all the gears just fine or it feels like it to me but as i was driving along its like u just kicked it up into neutral rpm's go up and spped drops so i let off it and get on it again and everthing is fine drive for a few hundred feet then it does it again
Old Dec 16, 2007 | 06:06 PM
countrysF250
BTW O/D light and button still work and its not flashing
