Odomer reading jumped
Old Dec 15, 2007 | 06:36 PM
dieselator's Avatar
dieselator
Unhappy Odomer reading jumped
This sounds crazy... I can't believe it myself. After plowing for an extended period of time w/ my 04 350 6.0L, battery power was so low, the truck stalled when I hit the button to raise the plow. After a jump start, I had the alt tested, charging fine. Both batteries load tested fine also. The tech I spoke with suggested cleaning the terminals really well and giving the batteries a full charge and reconnect. So my odometer reads 23684 before I did this, now it reads 38739! I magically put 15000 miles on in my driveway with the hood up. Is there any known cause for this, and more importantly, is it reversible?
Old Dec 15, 2007 | 10:36 PM
grinekb's Avatar
grinekb
take it to the dealer. you have to let them work on it. My last truck the odometer stopped working and i was gonna fix it myself until someone informed me that odometer tampering and i would never be able to sell it.
Old Dec 16, 2007 | 01:37 AM
riggz's Avatar
riggz
Just think, you can now claim to having the best fuel milage of ANY vehicle on the road!
Old Dec 16, 2007 | 07:43 AM
diverseth's Avatar
diverseth
Don't forget to bring any proof that you have of the actual mileage like receipts for tire rotation or oil. I’m sure the dealer will be very leery of this assuming you are trying to extend your warranty or jest rolling the miles back. WOW that sucks. Best of luck I hope it works out. Let us know what happens.
Old Dec 16, 2007 | 08:17 AM
msgtg's Avatar
msgtg
I know there's a way to flip from miles to kilometers....I'd make sure this didn't happen before I took it somewhere.
Joe
Old Dec 16, 2007 | 09:17 AM
riggz's Avatar
riggz
Joe
Hah! That's a very good point. The mileage would be just about right if it switched to Km. 23684 miles = 38115 kilometers
Old Dec 23, 2007 | 12:00 PM
dieselator's Avatar
dieselator
Odometer reading jump after battery reconnect
Thanks for the advice guys. The odometer is registering in kms and not miles, 2.4+ for each mile driven. I did take it to the dealer and they are blown away also, as they can't find any way to swap it back. I have another appointment with a different dealer that has more experienced techs with the electronics, recommended by the first dealer. I hope they can come up with something. I know the PCM registers alot of details, number of keystarts, etc. Does anyone know if it registers the odometer reading between keystarts? It would be helpful to make my case.
Old Dec 23, 2007 | 12:56 PM
traveller1002000's Avatar
traveller1002000
Is your truck a Lariat? If so there should be a way to change to metric and back to standard by accessing the menu. I know mine can be changed that way.
If not your dealer should be able to check it out with the IDS computer?
Bill
Old Dec 23, 2007 | 01:14 PM
mudnthundr's Avatar
mudnthundr
Or you could just move to Canada am be on the km system......problem solved!
Old Dec 23, 2007 | 02:52 PM
msgtg's Avatar
msgtg
What model truck do you have? You may be able to change it at the dash info module....I can't believe the dealership couldn't help.
Joe
Old Dec 23, 2007 | 05:25 PM
F250tuff's Avatar
F250tuff
He says he has an '04. I don't know if it is the same as my '06, but if it is, here are the instructions on how to change it using the buttons located to the right side of the steering wheel:
Setup menu
Press this control for the following
displays:
• System Check
• Units (English/Metric)
• Autolock
• Autolamp Delay
• Language
System check
Selecting this function from the
SETUP menu causes the message
center to cycle through each of the
systems being monitored. For each
of the monitored systems, the
message center will indicate either an OK message or a warning message
for three seconds.
Pressing the RESET control cycles the message center through each of
the systems being monitored.
The sequence of the system check report and how it appears in the
message center is as follows:
1. ENGINE TEMP
2. TRANS TEMP
3. OIL PRESSURE
4. BRAKE FLUID LEVEL
Driver Controls
5. DOOR AJAR
6. FUEL CAP (gasoline engine only)
7. AIR FILTER (diesel engine only)
8. FUEL LEVEL
1. Select this function from the
SETUP menu for the current units
to be displayed.
2. Press the RESET control to
change from English to Metric.
