Bill, I have never seen a Anodized aluminum grill for a 61 or a 62.........Please show me one.......I would like one of those.....
Steel and Chromed Steel Yes Aluminum No....
Give Tom at Flashback F100s in North Carolina a call, he always has a stock of NOS or desert metal steel 61 and 62 Grills.
Garbz
Hmm...well I knew the grilles were bright metal, and just assumed they were like the later models which were aluminum (parts catalog doesn't say). It's been quite awhile since I actually had one in my hand.
I Have had the painted 61 and a Chrome steel 61 grill and 62 Steel and Chrome chrome steel, but never an aluminum one for those years. The first i ran across a aluminum grill was in a 63.
thanx. yeah im familiar with which are which and such, just wondered where to look for em. thanx for the info on dealers i'll check em out. which ever i get im gunna chrome so it doesnt matter to me.
next question... no since in making a new thread
any ideas what gear i have in my truck? i believe it was a 6cyl 3 on the tree truck. it should be the orginal 9in. the tag is missing and i dunno what ive got.
guesses? what was available in 6cyl trucks?
next question... no since in making a new thread any ideas what gear i have in my truck? i believe it was a 6cyl 3 on the tree truck. it should be the orginal 9in. the tag is missing and i dunno what ive got.
The AXLE code is on the Warranty Plate. It can be decoded here if you post it. My guess it's either 3.70-1 or 3.93-1...unless the gears have been changed.
And...it may NOT be a 9 inch. Ford from 1961/67 installed Spicer (Dana) 44's in the rear if the truck was ordered with Limited Slip.
There's another (optional) F100 rear end used 1961/67, the Spicer (Dana) 60.2. This was considered a heavy duty rear end, and this Dana 60.2 uses 5 lug 5.50" bolt circle wheels.
NOTE: Spicer rear ends have a removable inspection cover, Ford 9 inchers do not.
You aren't dumb, there's a lot of ppl that don't know where the Warranty Plate is.
No one can learn everything about their trucks overnight.
Scheiss, I never heard the term "Slick" till I joined FTE.
Warranty Plate aka the Rating Plate on later models: On the inside of the glovebox door 1961/thru early 1963, and on the left door face near the latch on late 1963's thru the 1980's.
It can be folded in half.......But not quarters....
I need the 2 lower bars cut about 3 inches past the turn signal bucket along with a chunk of metal behind the head light door.
My old gallery garbz has a shot of the custom 63 grill i made for my Pro Street truck. I want to do a similar grill for the 63 Uni. I removed the turn signal and metal shaped the lower bar to replace it.
