ANOTHER Oil Cooler Question
Old Dec 15, 2007 | 02:09 PM
newr's Avatar
newr
Pulled the oil cooler from my 7.3 apart today to clean it up and put in new O-Rings. I had previously figured out that the PO had put some sealer in the radiator but it didn't dawn on me until I Looked that the same sealer would plug the oil cooler. Pretty obvious now, I just hadn't put the two together before. So, now I have to figure out a way to clear the water passages.
My first thought was to run a piece of drill rod through the water passages and push the sealer out. Then follow with some solvent to clean the walls of the tubes.
My question for the list is how careful I need to be about cleaning/flushing the main tube. It looks to be a pretty robust assembly, I doubt if I'm going to hurt anything, but I also don't want to assume that a good solvent rinse will work and then end up with a dead motor either. Can I put this tube in my parts washer and give it a good scrub?
Thanks in advance.
Ron
Old Dec 15, 2007 | 11:56 PM
Dave Sponaugle's Avatar
Dave Sponaugle
I would do the solvent, leave the rod in your tool box.
Right now I am brain dead, but I think I remember something about the coolant passages having an odd shape to help absorb more heat.
Old Dec 16, 2007 | 08:36 AM
dixokai's Avatar
dixokai
Radiator shops can give it a bath and it will come out looking like new.. Just a thought
Old Dec 16, 2007 | 10:10 AM
starmilt's Avatar
starmilt
use the solvent then compressed air.
Old Dec 16, 2007 | 01:32 PM
newr's Avatar
newr
Hmmmm, that does make sense, but holding the tube up like a scope and looking through it there are passages that are straight through, others that I thought were blocked by the Radiator sealer. They could just as easily be different a shape.
Sounds like a good bath is in order.
Ron
Old Dec 16, 2007 | 10:28 PM
PLC7.3's Avatar
PLC7.3
If I'm not mistaken the tubes are spiral........
