Turbo discovery
Old Dec 15, 2007 | 12:28 AM
3000 FPS's Avatar
3000 FPS
Turbo discovery
I have a turbo that I bought which is the latest remanufactured from ford.
It has part # 5C3Z 6K682. I opened up the turbine exhaust side so I could look at the design of the unison ring and the veins. I thought maybe I could come up with a different material for the unison ring that would resist rusting. I used a magnet on the ring and low and behold it is completely non magnetic. This means to me it is already made of some kind of material that does not rust. The veins had a slight amount of magnetism and of course the housing itself pulled very strong. So has ford changed the material that the unison ring is made from, to help stop the sticking problem? Has anyone ever had an older one apart and notice that the older turbos had a unison ring made of steel? Just curious if there were other changes made other than the machining they did on the housing to allow for less contact of the unison ring.
Old Dec 15, 2007 | 10:09 AM
Super08's Avatar
Super08
I wonder if that is the one in my 07 (sept 06 build). Either way it is a little over a year old and no troubles yet.
Old Dec 15, 2007 | 11:52 AM
3000 FPS's Avatar
3000 FPS
I believe that the turbo on your 07 is the same and probably does have the same modifications as the one that I listed here.
gmblack
Nov 20, 2011 08:43 PM
BobbyB
Sep 26, 2011 10:17 AM
3000 FPS
May 16, 2011 08:57 PM
zoommx
Nov 9, 2010 07:13 PM
3000 FPS
Dec 20, 2007 08:24 AM
