1990 Bronco cam change problem
Old Dec 15, 2007 | 12:01 AM
axbrya's Avatar
axbrya
Hi Everyone, <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
I have a 1990 Bronco with a 302 with 31,000 miles on it. I put in a new sum3600 cam, new timing chain and gears. I brought it up on tdc, aligned the timing marks, reassembled everything. I put the distributor on #1, the truck tries to run but doesn't, I've moved it a tooth both ways. Is there something I'm missing? Can anyone help? <o></o>
<o></o>
Thanks Arnie <o></o>
<o></o>
Old Dec 15, 2007 | 01:38 AM
red58's Avatar
red58
just a guess its not 180degrees out on the dizzy is it,its easy done and they will try to run that way,also do you have the correct firing order setup,15426378 or 13726548,
Old Dec 15, 2007 | 08:23 AM
axbrya's Avatar
axbrya
I think I have the firing order clockwise instead of counter clockwise. It uses 15426378. Rookie move
Old Dec 15, 2007 | 09:57 PM
red58's Avatar
red58
as long as ya dont damage parts doing it yourself is the best way to learn,cheers
Old Dec 21, 2007 | 11:18 PM
axbrya's Avatar
axbrya
Thanks everyone, yes firing order is counter clockwise.
mt54
Mar 1, 2008 06:52 AM
RV-Dean
Feb 26, 2008 04:38 PM
fly4fun35
16
Feb 20, 2008 10:17 AM
mmccasli
Nov 20, 2007 08:29 AM
pforr
Feb 23, 2007 01:38 AM
