eratic speedometer
Old Dec 14, 2007 | 08:53 PM
ackack's Avatar
ackack
eratic speedometer
95 f150 5.8
my speedo needle jumps around above 50 mph. What could be causing that, the speedo itself or something else? Thanks for the help
Old Dec 14, 2007 | 09:23 PM
superduty4x4's Avatar
superduty4x4
PSOM- programmable speedometer/odometer module. It's a computer chip that sits behind the speedo and stores the mileage for your rig. You can pick up a used cluster from a junkyard, but whatever mileage that rig had will now show on your truck. You can also try the vehicle speed sensor (VSS)- its a small sensor mounted on the top of your rear differential that sends the speed signal to the PSOM.
Stephenhutto
1997 - 2003 F150
Dec 20, 2009 04:33 PM
adelyser
1978 - 1996 Big Bronco
Oct 10, 2002 01:48 PM
msalvetti
Jan 19, 2002 12:51 PM
73Custom
Jun 6, 2001 08:16 PM
PAUL_2
Oct 29, 2000 11:30 PM
