question on making manuel steering easier
Old Dec 14, 2007 | 08:36 PM
X36's Avatar
X36
I'm looking for opions on how to make turning with manuel steering easier.narrower frt tires ? smaller or larger diameter steering wheel than OEM and anything else ?? Thanks
Old Dec 14, 2007 | 08:39 PM
Mil1ion's Avatar
Mil1ion
Spinach !
Breakfast.Lunch, Supper
Old Dec 14, 2007 | 11:01 PM
rmalottwtes30's Avatar
rmalottwtes30
lol Dennis...Thats true though, make sure ecerything is smooth by greasing it and making sure all bearings are in good shape...Or go find an old junker and get the power steering assembly...
Old Dec 14, 2007 | 11:16 PM
rocktruck's Avatar
rocktruck
Hi. If your truck came with manual steering originally, I believe it also came with a slightly larger diameter steering wheel than used with PS. I'm wondering if someone replaced the original wheel with a smaller aftermarket wheel?
Wonder if a heavy duty truck wheel is even larger diameter than the stock manual wheel, and would fit?
Or do as already suggested and swap in PS.
Old Dec 15, 2007 | 12:14 AM
highboy1975's Avatar
highboy1975
swap in ps! theres nothing gonna make it any easier if everythings lubed well and in decent shape.
Old Dec 15, 2007 | 01:59 AM
tylstruck's Avatar
tylstruck
That's a grand one, Dennis. I don't think the PS vs Manual steering wheels were larger or vice versa. The columns are different at the end. The medium duty trucks and heavy duty trucks steering wheels are larger.
My one ton trucks have the same steering wheels as a half ton truck, with or without PS. Anything over a ton has bigger wheels all around.
Tyl
Old Dec 15, 2007 | 09:56 AM
Pro-Street/StateTK's Avatar
Pro-Street/StateTK
78f250supercab
I have drove F-100s without power streering for years, and it becomes a
''style of driving'' try to make sure to cut your wheels slowly while moving,
like when backing up cut the wheel while moving. It's a lot easier on your
back, neck, shoulders, and on your streering column! Try it,it works great!
Wally Womack
Old Dec 15, 2007 | 04:04 PM
tylstruck's Avatar
tylstruck
My uncle says back in the old days driving a semi with no power this or that on trucks, was all in the bi-cepts hince the sport or game of arm-wrestling.
My trucks have no ps on a heavy one ton chassis. Wanna feel my guns? ahha. It's not to bad to steer when you're rolling. Advoid trying to turn when you're at a dead stop, and avoid dead end streets.
Tyl
Old Dec 15, 2007 | 04:26 PM
Mil1ion's Avatar
Mil1ion
It wasn't called "Armstrong Steering" for nothing.
These trucks are nothing compared to a 1963 White Concrete truck a 5 and 4 trans with manual steering and 10" x 20" tires.
Old Dec 19, 2007 | 06:38 PM
George Frasier's Avatar
George Frasier
Addendum to the "spinich" post - add a can of oysters @ lunch time.
Old Dec 19, 2007 | 11:16 PM
jfarcas's Avatar
jfarcas
I'm actually looking to swap my p/s sytem out for a manual one. I prefer the simplicity of the system, and on a 2wd, i'm not too concerned with the increase in elbow grease needed to turn it at low speeds.
I saw mentioned above, though, that the column is different for p/s and m/s. Will I need to grab another column as well as another manual box in order to do the swap?
(And, if anyone wants my p/s pump or box, I'd be willing to give it away - they'd be good as cores)
