Computer and rear question.
Old Dec 17, 2007 | 06:47 PM
MADVAN's Avatar
MADVAN
Run it on the scales. You might be suprised.
Might need a diet first.
The E-SD is like a cinder block going down the road.
Its areo is the pits.
Also needs a tach.
Check the PCM code. I would like to see what it is.
Might have a Ryder (rentals) code (PIG)
A 97E can run strong. It has split inj's.
Bill
Old Dec 17, 2007 | 07:25 PM
trike1946's Avatar
trike1946
I know it is a bit heavy. But it is the same size as my 96 which runs really strong. Same engine and trans but different rears. The 96 has a 4.10. I have a tach in it (the 97) and a set of gauges. Where do I find the PCM code?
If I hit the same long hill with both trucks towing a trailer, doing 50, the 96 might drop to 40, and the 97 will drop to about 10. I think I need to get out and push sometimes.
Old Dec 17, 2007 | 08:01 PM
MADVAN's Avatar
MADVAN
Look under the dash above the throttle pedal. You will see the back of the PCM. The code is on the black cover. Good chance a code change/flash ect will help with the power. I would have been glad to see it was not 3.55. Its less money and work. The 97E chipped will run circles around your 96F. The E has the bigger splitshot inj's and down pipe.
Bill
Old Dec 18, 2007 | 08:08 PM
trike1946's Avatar
trike1946
MADVAN, my 96 is where you said but the 97 is on the fire wall behind the overflow bottle. I can see a lot of numbers on the area of the plug connection. Are any of these the numbers or should I pull it out and look behind it?
Old Dec 18, 2007 | 08:13 PM
MADVAN's Avatar
MADVAN
Get it from the backside. No need to take anyting apart.
Just look above the gas pedal with a flashlight. If the cover is not on it, then you will have to get the code from the engine compartment. You have to remove the connector to see it.
Bill
Old Dec 29, 2007 | 04:09 PM
trike1946's Avatar
trike1946
I'm back. I got distracted with Christmas. The only thing I see on it are:
MADE IN BRAZIL
PWB 4130
IDM 100 SAEO
F7TF 12B599-AA
7F20-3
7FAAO
*082TWQXO*
Is any of that the code?
Old Dec 29, 2007 | 04:17 PM
MADVAN's Avatar
MADVAN
Thats the IDM.
The PCM goes threw the fire wall.
Bill
Old Dec 29, 2007 | 05:17 PM
trike1946's Avatar
trike1946
Darn, I thought it was too easy. I'll look again tomorrow.
Old Dec 29, 2007 | 06:26 PM
MDB's Avatar
MDB
Yeh, get a programmer and it should kick the power up a bunch, particularly in the Race or Extreme mode. I have an Edge Evolution that is like new if your interested. It makes a heck of a difference in power, that's for sure!
kountzecobra
19
Aug 30, 2015 08:08 PM
andrewzx92000
Nov 11, 2013 11:48 PM
gitane59
Modular V10 (6.8l)
18
Aug 28, 2008 03:35 PM
Cowboy34
17
May 17, 2006 01:46 PM
FlyinFord
Mar 29, 2005 12:33 PM
