300 Straight 6 Experts
Old Apr 16, 2001 | 06:24 AM
DeenHylton's Avatar
DeenHylton
Hi guys, can anyone give me specs on the 300? I need Bore/Stroke,
Intake/Exhaust valve sizing, Carb or Fuel Injection CFM. Also are the valves in the head or in the block. I want to run the numbers through the "Dyno 2000" program for a fellow Ford Truck enthusiest. Thanks! Deen
Deen Hylton
Ford F250 460 C-6, K&N, Headers, Dual Exh.,Comp. Cams,Shift Kit
Pioneer CD w/Bose Speakers.
Other Passion: Blown 77 Corvette (Sorry Guys/Gals)
How I can afford to Drive the above: 93 GEO Metro
Old Apr 16, 2001 | 04:49 PM
StrangeRanger's Avatar
StrangeRanger
Figures for a 96 are:
Bore: 4.00
Stroke: 3.98
I Valve: 1.78
E Valve: 1.56
Cam lift .249
Duration 192* @.050
Valve lift .398
CR 8.8
Head volume 68.4-65.4cc
Airflow? enough to support 84#/hr of fuel@WOT on the SEFI version, about 390 CFM which I beleve was the rating on the carbed version as well.
Valves are overhead, Ford hasn't built a production flathead engine in over 40 years.
You're going to find very low volumetric efficiencies are inherent in the long stroke engine, please post what you find though.
Old Apr 17, 2001 | 06:24 AM
DeenHylton's Avatar
DeenHylton
Strangeranger thanks! I'll get the info posted but it won't be untill next week...I leave for 5 days starting tomorrow.
Deen Hylton
Old Apr 17, 2001 | 06:32 AM
TallPaul's Avatar
TallPaul
Wow! Thanks Strange Ranger! I posted on several bulletin boards several months ago trying to get duration on that motor. I assume duration is the same for both intake and exhaust. Can you tell me one more thing though, what is the degrees before/after dead centers for the intake and exhaust?
Old Apr 17, 2001 | 03:45 PM
StrangeRanger
For starters there's a typo, it should be 194*@.050. Don't have timing events, but they have got to be VERY mild with that small a duration. I don't remember the source of the info either, it sure as hell wasn't Ford, they keep info on the 300 a very dark secret.
Old Apr 17, 2001 | 09:35 PM
mrlaserboy's Avatar
mrlaserboy
I've got the Ford Engine shop manual for 1988 light duty trucks and it lists most of those specs listed above.
Dustin Siebert
mrlaserboy(No Email Addresses In Posts!)
Registry: http://www.superford.org/cgi-bin/sf.cgi?uid=default&vr2=1&ID=201
Home Page: http://www.superford.org/users/ylobronc/index.html
'88 Bronco XLT 302EFI/AOD/BW1356/44IFS with 8 lugs(open)/10.25 FF(Lockright locker)/4.56/6" Superlift/2" BL/35's-street/38.5's-trails
2 BIG BRONCOS 4X4 CLUB - GREAT LAKES CHAPTER http://www.2bigbroncos.org
Old Apr 18, 2001 | 03:47 PM
StrangeRanger
The numbers I quoted, except for cam duration are out of the Ford 96 shop manual. Ford doesn't seem to think we should know duration
Old Apr 18, 2001 | 05:12 PM
82F100SWB's Avatar
82F100SWB
