lift help
Old Dec 14, 2007 | 04:17 PM
fordman68's Avatar
fordman68
lift help
i wanna lift my truck about 4 inches and run 33s ik i can go bigger but thats what im going with for know i wanna know what is better for a daily driver 4inch suspesion or 2 inch body 2 inch suspesion?
Old Dec 14, 2007 | 06:56 PM
unrulee's Avatar
unrulee
ALL SUSPENSION LIFT, always if possible. Especially if your only looking for four inches of lift.
If you already had 12 inches of lift, then yeah a body lift would be ok.
If your looking to save some coin you could just shackle flip the rear.
Old Dec 14, 2007 | 07:49 PM
Pickupmanx2's Avatar
Pickupmanx2
Check out my gallery on my 77, those are 33 1/2" tires (255/85/16) and I only added front 1 1/2" lift/leveling coils and 2 degree C-bushings. I have test fitted 35's on the front just in case I want to..... I don't. For a daily driver, 33s are great, coils, ALL bushings, tires AND rims was just a hair under $1400. The coils were $125, bushings,,,, C-bushings, radius-arm bushings were $50, the rest was tires and rims.
Joe
Old Dec 17, 2007 | 06:45 PM
midcal48's Avatar
midcal48
i would like more information on this shackle flip??
Thanks
Old Dec 17, 2007 | 11:02 PM
unrulee's Avatar
unrulee
Look through these posts that came up under shackle flip when I used the search function on this site.
https://www.ford-trucks.com/forums/s...6&pp=15&page=1
Old Dec 18, 2007 | 12:27 AM
ncfirefighter46's Avatar
ncfirefighter46
check out 4wheelparts.com that is where i order a super lift 6" and everything i needed and 34inch tires too all for around 1300.00. i got springs, drop pitman arm, adj track arm, drop raduis brakets, es 1000 shocks w boots, 4 inch blocks, and add leafs, c bushings, and my tires superswampers, 34"
Old Dec 18, 2007 | 02:30 PM
FordTrucksKickGM's Avatar
FordTrucksKickGM
For 33" tires Id just go with a leveling lift. New springs all around and Id ditch the factory rear blocks.
