i'm having a problem with my tail lights. when i bought the truck there were absolutely no wires going past the end of the cab - nothing to lite up the tail lights. since then, i have wired everything up with the exception of the backup lights. lately, i have been having problems with the lights not being as bright one side as the other and intermittent problems with different sides that has already gotten me pulled over once. anyone know of a site on the web where i can buy partial or full wire harnesses? i am tired of my splices not doing the job and want to replace it with something close to original. thanks
'79 F-250 4X4 300 I6/4 spd man 3" lift with 35" grabber mt's
You should be able to get the harness at your local dealer or from a salvage yard. If not, your best bet will probably be to make your own. Just make sure to use good, quality wire and flex-tubing to protect it. Solder all your connections, as the crimp type connectors will hold moisture and corrode.
