whats the problem here?
Old Dec 13, 2007 | 10:55 PM
Truckin4life's Avatar
Truckin4life
Street Queen to the extr3m3
alirght i have a 1995 250, 351w with a 5 speed manual 4x4. Now the problem is that when im starting off, the truck feels like something is holding it back, like im trying to drive with the parking brake engaged, but the brake is disengaged. Im sure of it, if i engage it its even worse taking off. How would i be able to tell if my breaks are dragging, and would it be that bad? Sometimes if i dont gas it enough my truck struggles for a second, and thats in granny low. If its not dragging breaks what could it be? There is something deffinetly holding me back. Thats all i know.
Thanks,
Don
Old Dec 13, 2007 | 11:11 PM
dixokai's Avatar
dixokai
Jack it up and see if you can spin the tires by hand.
Old Dec 13, 2007 | 11:22 PM
17fordguy's Avatar
17fordguy
could possible be a cloged cat. when mine went bad it felt like i was towin a trailer a just wouldnt go any were. does the truck slow down dramaticaly if you let off the gas and dont press the break.
Old Dec 14, 2007 | 12:44 AM
phoneman91's Avatar
phoneman91
After driving the truck--check the rear drums with your hand and see if they are very hot. And check the front hubs and see if they are very hot. They should be warm --but not extremely hot--unless you braked very hard before checking. If one hub or drum is more hot than the others--that wheel location has dragging brakes or wheel bearing problems.
Old Dec 14, 2007 | 05:38 AM
fmr9's Avatar
fmr9
The clutch fan can cause the symptoms you are describing, if it fails and runs all the time. I know it is hard to believe, but several people have reported it was like dragging a boat anchor.
Good luck
Frank.
Old Dec 14, 2007 | 10:03 AM
Idaho Charley's Avatar
Idaho Charley
Cold weather and a little moisture sometimes freezes/frosts the caliper slider area up. The front calipers may not be retracting freely due to a combination of rust and frost IMHO.
I have to physically remove the front calipers every couple of years and clean-up the area where the 'rubber/metal wedge' piece in order to prevent the same thing from happening. Once the wheel is off its is a 5 minute job to drive out the wedge, clean-up the area with a wire brush and then I very lightly lube the wedge with brake caliper grease.
Old Dec 14, 2007 | 12:46 PM
Truckin4life
The fan clutch sounds like a place to start, i no longer have a cat on my truck, dual glass packs. I will check the breaks dragging, when ever i take off in 1st and the i push in the clutch to shift i come to almsot a complete stop. But after i drive it for 100 yards or so, then it wont do that, unless i stop for a minute again. Its odd, could the breaks be sticking shut, stopping me, then once they get a little bit warmed up the loosen up and stop dragging, i dont really know whats going on but its frustrating me, i hate not knowing whats wrong with my truck.
Old Dec 14, 2007 | 07:44 PM
fmr9's Avatar
fmr9
This really sounds like your brakes are dragging. Don't think the clutch fan would come and go like that.
Frank
Old Dec 16, 2007 | 11:21 PM
Truckin4life
alright well ill check it, ive had a hectic weekend, maybe ill get a chance tomrorow during lunch or something. Thanks for all the input guys, ill let you know what i find out.
Later,
Don
Old Dec 20, 2007 | 04:02 PM
n8pete's Avatar
n8pete
i have that same exact thing going on. it stutters when it accelerates from low gears and feels like im dragging my trailer. i havent checked the hubs or whatever to see if its hot. i also havent checked the clutch fan, mainly cuz i dont know what the hell it is haha. the repair guy at tunex told me it was my spark plugs, fuel filter and fuel pump so i replaced the fuel filter and plugs and it was good for a couple days and started doing that again. first problem ive ever had. which sucks cuz im trying to sell it.
lonewolf121
13
Feb 16, 2012 09:02 AM
G2IC_Wraith
1983 - 2012 Ranger & B-Series
May 4, 2007 08:03 PM
Hometown Pride
Dec 11, 2006 10:11 PM
cbslayer
20
Nov 23, 2006 08:45 AM
sittingtalltree
May 9, 2002 01:56 PM
