302 compression
Old Dec 13, 2007 | 07:51 PM
smurph78's Avatar
smurph78
302 compression
I've pulled a 302 out of a 77 2wd to put in a 4wd. The engine runs and doesn't smoke or use oil. the compression on #1 was 145 lbs, #2 #3 #4 were up around 150-155. #5 - #8 were all around 160. Will this cause problems in the future. Plans are to run it until it quits or until I find a winsor or save up to rebuild the 302.
Old Dec 13, 2007 | 08:03 PM
MattV's Avatar
MattV
I wouldn't worry too much with that little bit of variance. Keep running it! Just my opinion.
Old Dec 13, 2007 | 08:12 PM
smurph78's Avatar
smurph78
i hope it holds up. truck sat up 6 months. tuned it up then pulled it out. its sitting in the shop waiting on the 4wd to be done
Old Dec 14, 2007 | 05:41 AM
HemiEater's Avatar
HemiEater
run it......
Old Dec 18, 2007 | 11:54 AM
red89notch's Avatar
red89notch
tehre is no set rule for how much compression a engine should have as each is its own.
the only rule of thumb with compression is it should be within 5% of each other.
and you are so run it
Old Dec 21, 2007 | 06:21 PM
smurph78's Avatar
smurph78
i've also read that a manual trans starter and an auto trans starter were different
Old Dec 25, 2007 | 12:45 PM
Boba Fett's Avatar
Boba Fett
They are.... depends on flywheel (for manuals) flexplate (for autos) teeth. For instance... a car small block starket will not work on a small block truck... I think the same is true for automatics....
Old Dec 25, 2007 | 05:23 PM
HemiEater's Avatar
HemiEater
I believe that is the only difference in the Small block starter... I'm sure i have use the same starter for a 164 and 157 "or whatever the tooth count is" flywheel...But I could be wrong.....
Old Dec 27, 2007 | 08:34 PM
smurph78's Avatar
smurph78
i have 1 starter from a 351c manual and a 302 auto so i should be covered i guess.
