Timing Flathead:
Old Dec 13, 2007 | 07:14 PM
leonharu's Avatar
leonharu
Timing Flathead:
If you time a flathead like it says in the owners manual is that pretty accurate?The book says to line up timing marks and rotating distributor until the spark then lock it down!I don't have a light to use.
Old Dec 13, 2007 | 09:34 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Do you have a vacuum gage? The static timing method you describe is a good way to get an initial setting, but a better way is to hook up a vacuum gage (to manifold vacuum, not the dizzy advance vacuum). Advance until vacuum maxes, then retard until 1" below peak vacuum. Test drive to make sure there's no pinging, retard a little at a time if needed. Don't go more advanced tho.
Old Dec 14, 2007 | 12:34 AM
mtflat's Avatar
mtflat
I do mine like the book says - sorta. I line up the marks and then set it where I get the throttle response I want thru the whole range from off-idle to wot. I have a timing light but don't bother to use it. Flatheads are easy. Been doing it that way for 6 years on my daily driver.
I'm sure Ross is right on, but I don't have a vac gauge.
Old Dec 14, 2007 | 08:22 AM
ALBUQ F-1's Avatar
ALBUQ F-1
The method I described is Rumbleseat's, a flattie guru's. Last time I set it this way, it ended up right at the stock marks!
Old Dec 15, 2007 | 01:38 PM
PerfDistIgnition's Avatar
PerfDistIgnition
FTE Sponsor
Of course, the best method is to have the advance curve set up on a machine.
http://www.performancedistributors.c...ead%20ford.htm
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
ChristiansenP
Jun 15, 2016 05:03 PM
Damifiknow
33
Dec 17, 2011 07:26 AM
mweaver
Feb 20, 2007 10:45 AM
rrm99a
1947 and Older Ford Trucks
Jan 13, 2005 08:16 PM
dustof45
Aug 21, 2003 11:33 AM
