Flathead V8 Rebuild Video
I'm guessing most have seen this, but I just ran across it today, and it was way too cool not to share. I was mesmerized!!
Check it out!
Watch A Beautiful Time-Lapse Of A Flathead Ford V8 Rebuild
Check it out!
Ross, could you explain this to me? Does sandblasting pit the pan enough to cause issues? My novice mind, doesn't see an issue with it....unless you don't get all the blasting material out?
My only question is why? Nobody sees the inside so if there are stains IMHO . . . so what. Is the pan rusted so badly that it could be perforated. I would worry about getting all the sand out.
Bingo! Few pans are totally smooth inside, in particular flathead pans have several areas where sand can be stuck in a crevice until engine vibration knocks it loose.... and there it goes thru the oil system.
My engine's pan had rust just above the oil level line. The normal caustic vat didn't get it all, so they acid vatted it. Nothing but some staining now.
old_dan
03-21-2015 07:29 PM
island89
05-24-2004 11:23 AM
