MAF replacement
Old Dec 13, 2007 | 06:34 PM
texasfirewalker's Avatar
texasfirewalker
Question MAF replacement
Anyone help with step by step removal and cleaning or the install of a new MAF. on a 04 5.4? Would appriciate ANY help! Wanna try to clean it first before I fork over the bucks for a new one. Heard my K&N might be fouling it from the oil in the filter... Thanks
Old Dec 13, 2007 | 07:45 PM
5 Star Tuning's Avatar
5 Star Tuning
Former Vendor
My advise when cleaning MAF is too, hold it upright when cleaning it to prevent the cleaner fluid entering the housing all together.....Napa has the best brand in my opinion.
Old Dec 13, 2007 | 08:58 PM
ford390gashog's Avatar
ford390gashog
Its held on by 2 T10 torx screws. In and out in 5 mins tops.
Old Dec 14, 2007 | 05:56 AM
FS-150's Avatar
FS-150
Are you giving your K&N time to dry before you reinstall it? I have used a K&N on my Mustang for over 10 years and not had a problem with the MAF. If you do clean the MAF, do not touch it, only spray it with electrical contact cleaner (does not leave a residue) let it air dry and replace.
Old Dec 14, 2007 | 09:06 AM
texasfirewalker
Thanks for the help, everyone! The K&N hasn't been cleaned yet, so it is still the factory oil job. Thought of replaceing it with just the regular Motorcraft filter to see if there is any improvement after cleaning. The reason for suspecting the MAF is bank 1 & 2 is showing a lean condition. Also, the crank position sensor is showing a signal error. Where to begin, where to begin....
Old Dec 14, 2007 | 01:41 PM
VFR_Man's Avatar
VFR_Man
When is the last time the fuel filter was changed? Stopped up fuel flow would make it go lean too I'd think.
BTW, I have K&N's in two vehicles and have not seen MAF fouling in either.
Old Dec 14, 2007 | 03:33 PM
osteodoc08's Avatar
osteodoc08
As mentioned, just get some electrical contact cleaner and spray it to clean it. Just spray the sensor in the middle of the two screens.
You might also find some spray cleaner labelled "MAF cleaner spray" or something similar. It is nothing more than electrical contact cleaner.
