How can I tell???????
Dec 13, 2007 | 12:19 PM
How can I tell??????? Factory vs Dealer air
How can I tell from Factory air conditioning to a dealer installed air conditioner?
I want to be able to buy the right parts for it the first time....
Dec 13, 2007 | 12:50 PM
Title should be: Factory air vs dealer installed air
Topic in the title of the thread please.
Integral Factory A/C has a huge box on the firewall and a control panel
above the radio
Dealer installed air has a A/C unit hanging from the dash.
Dec 13, 2007 | 01:05 PM
Thats all dealer installed looks like that with no vents in regular places even for heat...
Dec 13, 2007 | 01:08 PM
Shouldn't the condensor / compressor parts be pretty much the same for replacement and for recharging; even if you convert from R12 to 134. The factory or dealer installed are interchangeable beyond the dash board.
Mitch
Dec 13, 2007 | 01:10 PM
Im need to buy the blend air cable so trying to find out which one I need
one ford told me D3TZ-18518-B for factory and in the aftermarket parts its said that B is w/out factory air and -A is factory
Dec 13, 2007 | 01:26 PM
Dec 13, 2007 | 01:36 PM
Thanks for the illustration....but it doesnt have a or b at the end
Dec 13, 2007 | 01:38 PM
for the 18518-a or 18518-B
guess I'll ask for pictures or something from the aftermarket place
Dec 13, 2007 | 01:49 PM
Hang in there..I have many things to do right now
Dec 13, 2007 | 01:51 PM
Thanks....no prob its cold right now so I just have to manually move the switch to stay on heat....
Dec 13, 2007 | 02:08 PM
D3TZ-18518-A is for the AC regulator
B is for the heater temp control
Dec 13, 2007 | 02:20 PM
Dec 13, 2007 | 02:22 PM
I guess since it has air it will be the A/C???
Dec 13, 2007 | 02:28 PM
the link didnt seem to work...
I was told its called a blend air cable and the ford guy called it the same but gave me the D3TZ-18518-B (with Factory A/C)
Dec 13, 2007 | 02:50 PM
Thanks for the clarification, Dennis. I've seen the under the dash AC setup in another U-haul truck and always wondered what was that.
Tyl
